HELP ME! 7.5" vs 8" rear diff. ...????
Old Sep 3, 2007 | 01:35 PM
ezfire1's Avatar
Arrow HELP ME! 7.5" vs 8" rear diff. ...????
The rearend locked up on me in my 89 toy. I have found a used rearend out of an 85... are they the same and how can I tell if the 85 is a 7.5" or 8"? .... is there any way to tell without taking the third member out to measure the gears? Does the code on the axle housing indicate the size?
The good news is that I found the 85 complete rearend for $120!!! Thanks to good ol' Craigslist!!!!!!
Old Sep 3, 2007 | 02:49 PM
HAVOC's Avatar
http://toyota.off-road.com/toyota/ar....jsp?id=274535
have a look at the chart to find out which axle you have
Old Sep 3, 2007 | 02:54 PM
881stGenRunner's Avatar
is ur toy 4x4? if so any diff from 79-95 will work for sure
Old Sep 3, 2007 | 02:59 PM
Kaleb's Avatar
If you have a 2wd you should have a 7.5" ring gear in the rear. If you have a 4wd then you have an 8" ring gear. And 8" toyota housing from a 79-95 pick-up or 4runner will work.
Old Sep 3, 2007 | 03:07 PM
mt_goat's Avatar
You may want to consider the ratio as well. This becomes even more critical if you have a 4wd as the front and rear need to the same.
Old Sep 3, 2007 | 08:38 PM
ezfire1's Avatar
Thanks all who replyed - Just a quick update... I decided to quit being a sissy and get my hands dirty... lucky for me the 85 rearend has the same gear ratio (4.10) as my 89. The only difference is that the flange on the third member which the driveline bolts to has smaller bolt holes.
Old Sep 3, 2007 | 09:39 PM
thook's Avatar
What's the vehicles? You can probably swap the driveshafts out, if you don't want to mess with the pinion flange.
Old Sep 3, 2007 | 09:49 PM
stanley's Avatar
The 85 rear end is 2 inches shorter than the one is your truck. In 86 toyota made the axle wider to match the new ifs setup. If I were you I'd look for a 86+ rear...you might run into some clearance issues plus the narrower rear might be a little bit more unstable.
Edit: the above info is for a 4x4, I have no idea about the 2wd width.
Old Sep 4, 2007 | 10:11 PM
ezfire1's Avatar
Yeah, before I did the swap I measured them both. I just swaped the third member only. I was able to drill new holes in the 85 flange to fit my 89 driveline(temp. solution only!) until I have the time and money to rebuild the orignial 89 third with lockers.
Old Sep 4, 2007 | 10:24 PM
olharleyman's Avatar
If your interested I have a 90 4.10 with a 1620 lockright I let go for cheap plus the shipping.
jaretstuff
Aug 4, 2015 02:08 PM
v_man
Jul 23, 2015 04:01 PM
1996Taco
Jul 20, 2015 12:02 AM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
