Quick question on gas vents...
Old Sep 3, 2007 | 10:45 AM
budro's Avatar
I was wondering if there were any of you had a problem where while at the pump you weren't able to pump your gas at the full "speed", or I should say you had to pump it real slowly or else the pump would keep stopping because (and this is my geuss) it did not vent out the air from inside the tank?
Any help would be great.
thanks
Old Sep 4, 2007 | 07:16 AM
eric-the-red's Avatar
I sometimes have that problem, seems to depend on which gas station I'm at. Try pulling the nozzle out a bit and see if that helps.
Old Sep 4, 2007 | 12:17 PM
Jay351's Avatar
I can't have the nozzle all the way in, or it just stops. usually have to pull it out about 2"
Old Sep 4, 2007 | 04:13 PM
84sr5yoty's Avatar
Never had that problem on the 84 yoty in 23 years, but I have since had that issue with my 99 accord after some idiot back into my quarter panel in 2001. I really should look into it someday??
Don?t forget to run though the FMS on checking and diagnosing the charcoal canister. If it malfunctioning, it can cause the symptoms you are having.
Old Sep 4, 2007 | 04:27 PM
INFINITY's Avatar
my 80 has no smaller hole like the new vehicles so i have to hold it when i fill or it stops. or it will fall out!
Old Sep 4, 2007 | 04:36 PM
KevinInSac's Avatar
Some times it will click off constantly, sometimes that damn pump won't even stay in. Once, when it was clicking off, it actually jumped out. Sprayed a little gas on the ground. It's only happened on my truck, and none of the other vehicles I've driven...
jasonty
41
Dec 23, 2018 01:00 PM
nonstop
Jul 24, 2015 06:29 PM
icentropy
Jul 14, 2015 10:23 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
