new motor, weird studder
Old Aug 24, 2007 | 10:00 PM
TheBrain's Avatar
Arrow new motor, weird studder
I have an 88' x-cab SR5 with a brand new 22re, new clutch, plugs, wires, rotor, cap, RV Cam, Headman header with 2.25" all the way out. It run's real good and is super tourqie. But it has a wierd studder above idle when it's not under a load. When I drive it I don't feel it. The only thing I had to modify was the air injector tube that came off the factory exhaust manifold to an EGR under the intake manifold. I just capped off the end and plugged the vaccum line. But I was told that wouldn't matter. I'm starting to think it might?
Old Aug 25, 2007 | 11:25 AM
TheBrain's Avatar
Does ne-one know what pipe I am talking about and what exactly it does?
My header with out the injector pipe.
And it bolted up here where I made a flange and gasket for it and blocked it off.
Old Aug 25, 2007 | 03:47 PM
84sr5yoty's Avatar
That block-off plate is supposed to be bolted to the upper intake plenum side, not the metal EGR pipe.
Old Aug 25, 2007 | 03:56 PM
TheBrain's Avatar
That pipe is a pain in the a#$ to get off. Do you think it makes a differance?
anndel
Aug 28, 2015 04:56 AM
Dakotaneu
Aug 15, 2015 07:24 AM
trailgoat
Aug 13, 2015 05:54 PM
icentropy
Jul 14, 2015 10:23 AM
