gas tank repair?
Old Sep 4, 2007 | 10:44 AM
mojo4x420's Avatar
gas tank repair?
Posting for a buddy. He has a 91 pickup. He replaced his gas pump on the weekend and when he went to open the drain plug on his gas tank, it was fubard. From his description the plug turns, but the threads are ed. He wasn't able to remove the plug or retighten and it it's leaking some gas.
So I was thinking about just trying to weld the plug shut w/ my 220v stick welder.
Anyone have any idea ho I would go about this w/out blowing myself up?
Maybe not worth it. Anyone know if another gas tank would fit in from something other then a 3rd gen pickup?
cheers, rob.
Old Sep 4, 2007 | 10:49 AM
CanadianToy's Avatar
cheers, rob.
I can get tanks around here for $100 (used) for almost any vehicle. It is not worth blowing yourself up!
CT
Old Sep 4, 2007 | 11:00 AM
eric-the-red's Avatar
Let me know which part of Vancouver you're in, so I can watch for the explosion
Old Sep 4, 2007 | 11:01 AM
tc's Avatar
tc
The epoxy tank repair stuff works pretty well.
Old Sep 7, 2007 | 07:13 PM
toby's toy's Avatar
Be sure to top the tank off before you weld it. Bigger explosion that way.
Old Sep 7, 2007 | 07:19 PM
linuxrunner's Avatar
When I was in africa I saw a guy welding a hole in a desel tanker truck, just welding right on the side of the tank and it was one of those huge tankers that delivers gas to gas stations.... it was crazy!!
Old Sep 7, 2007 | 07:20 PM
MMA_Alex's Avatar
DO NOT WELD A GAS TANK UNLESS ITS BEEN GAS FREED, and certified gas freed.
best bet would be some of that epoxy liner for the tank.
oh, and diesel is different, although i still wouldn't weld a diesel tank there are a number of stories about lit cigarettes being put out in diesel tanks.
Old Sep 7, 2007 | 07:21 PM
CJM's Avatar
CJM
Or you could try and remove it and retap that bolt with a larger one and use a gasket around it.
Old Sep 7, 2007 | 08:17 PM
tc's Avatar
tc
That will happen with gas too - the liquid isn't flammable, only the vapor. As such, the recommendation to fill the tank above actually DOES increase the safety because it displaces the vapor with liquid.
Old Sep 8, 2007 | 06:29 AM
scrid's Avatar
gas tank repair
I usually remove them, drain, and take them the car wash and blast them out good after removing the sender/fuel pump assembly. Then sit them out in the sun for a few hours until thay dry up before welding.
In a pinch I would recommend that Magnum gas tank repair putty, I have used it before and it works great,...until it could be properly repaired that is
Old Sep 8, 2007 | 02:35 PM
MMA_Alex's Avatar
you're welcome to try it, and put a video on youtube.
skoti89
Sep 11, 2015 07:46 AM
accuracy
Aug 4, 2015 08:05 PM
pyramid
Jul 30, 2015 10:05 AM
pyramid
Jul 29, 2015 06:53 AM
