Replacing Fusible Link
Old Aug 29, 2007 | 01:41 AM
Gadgtgal's Avatar
Hi, I can see my Fuse is blown.. 1992 4Runner V6
How do I get to the 80A fusible link in the engine bay area? I understand it is held in by screws, but what do I need to do to the main fuse box area to get it out? Thanks.
Old Aug 29, 2007 | 07:53 AM
eric-the-red's Avatar
You have to seperate the top of the fuse box from the bottom. I think the two pieces just clip together.
Old Aug 29, 2007 | 07:38 PM
brandyn85's Avatar
yeah the bottom just clips off and you have to push the fuse through the bottom and there is a 10mm and a 8mm bolt on there holding the wires on i believe
Old Aug 29, 2007 | 07:44 PM
deathrunner's Avatar
Just don't pry at it. I busted mine up a month ago.....I'm a dumbass
You need to unbolt it from the bottom side.
Unbolt the whole fuse box, then it should be easy to seperate the fusible link portion.
Old Aug 31, 2007 | 07:13 PM
GenXr's Avatar
X2 word for word!! I pryed at mine and busted it up last month to. Definitely unbolt the box from the fender. Nobody mentioned this but you should really disconnect the battery first.
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
razorman8669
Jul 12, 2015 12:13 PM
ptb12
Jul 5, 2015 01:49 PM
