transmission dipstick?
Old Aug 25, 2007 | 07:24 AM
monst's Avatar
where on the 3vze manual is the transmission dipstick?
Old Aug 25, 2007 | 07:31 AM
CJM's Avatar
CJM
Manual gear boxes dont have trans dipsticks. You can check the fluid under the truck in the trans fill hole.
Old Aug 25, 2007 | 07:45 AM
monst's Avatar
I want to put synthetic transmission oil in, is there a recommend brand/type for the 3vze?
Old Aug 25, 2007 | 08:46 AM
MMA_Alex's Avatar
which trans is it?
on my w56 (on the 22re) i've had luck with redline mt-90
Old Aug 26, 2007 | 08:36 AM
monst's Avatar
not sure what transmission
1995 manual 3.0 4runner.
Old Aug 26, 2007 | 08:48 AM
eric-the-red's Avatar
Probably a R150. The synchros in those don't like GL-5 fluid, stick to a GL-4 type. Like MMA_Alex said Redline MT-90 works well.
Old Aug 26, 2007 | 09:19 AM
drew303's Avatar
I've yet to find GL-4 gear oil, anywhere...
They say meets GL-5 or meets and exceeds GL-4, GL-5 blah blah
or they say GL3 GL4 GL5 and nothing else
can anyone explain wtf is the difference between all the GL's or is this just a SAE quality rating? whats the deal?
my G54 loves this mobil 1 75w-90 tho
Old Aug 26, 2007 | 11:00 AM
MMA_Alex's Avatar
gl-5 is a high pressure gear oil which has additives that tend to eat away at brass. i believe the syncros in these transmissions are made of brass.
Old Aug 26, 2007 | 12:11 PM
thook's Avatar
Good, good thread here:
https://www.yotatech.com/forums/f116...uestion-98830/
Old Aug 26, 2007 | 02:13 PM
pennywize's Avatar
i love redline mt90. locally shops around here dont stock it, i always have to special order it. they usually stock redline mtl but i like the mt90. made my old rx7 shift waaaay better. im gonna put it in my w56 soon.
Old Aug 26, 2007 | 02:36 PM
UKMyers's Avatar
That little book in your glove compartment is full of absolutely amazing facts!!! Put some Redline MT-90 in there and call it good. You'll be amazed! Oh ya I'm gonna put your post in my sig line that's a classic one!!
Old Aug 27, 2007 | 04:55 AM
monst's Avatar
I knew i would have a famous quote one day. Anyways ill pickup some Redline MT-90. How much do I need?
Old Aug 27, 2007 | 05:38 AM
ewong's Avatar
read the owners manual - its spec'd there.
Off the cuff - about 4qts? maybe 5?
Also - xfer case too...
Old Aug 27, 2007 | 02:46 PM
thook's Avatar
Some of it also depends on how much of the old oil you can out. Drive it around and get the trans. hot before you drain it. More will come out. And make sure you can get the fill plug off before you drain it.
ToyotaMD
Sep 22, 2015 06:28 AM
briholt
Sep 20, 2015 10:26 PM
TransAmBandit
Sep 20, 2015 06:08 PM
viesail
Sep 5, 2015 04:23 AM
kelly1450
Sep 2, 2015 12:29 PM
