Cluck noise..pretty loud!
Old Aug 31, 2007 | 06:01 PM
92whiteyota's Avatar
Well i posted a couple weeks ago that after my bj spacers install i tore the passenger side cv boot, when then a week ago i installed my procomp shocks, now the passenger side makes this horrible noise clunking noise like the cv axle is just hanging there...anybody else have this problems...any idea's???? thanks in advance gentlemen
Old Aug 31, 2007 | 09:20 PM
Elvota's Avatar
Might it be possible that the shocks you installed are to long and the "clunk" is them bottoming out?
A simple check would be to put a ziptie on the exposed shaft and take it for a spin around the block. If the ziptie is gone after you hear the "clunk", it would be a strong sign that your shock is running out of room.
Old Aug 31, 2007 | 09:23 PM
DeathCougar's Avatar
Cluck noise? Did you check for the common Chicken problem? I have heard they can cause a loud clucking if not taken care of right away.
92: I had this same problem, it turned out to be my steering idler arm was shot. Lifting the truck made it worse.
Old Sep 1, 2007 | 03:59 AM
chicken problem??? But this cluck is bad when driving in 2wd on the highway or slower its like a loud rattle clunk.
Old Sep 2, 2007 | 07:52 AM
ttt...
Old Sep 2, 2007 | 08:00 AM
881stGenRunner's Avatar
like DeathCougar just said check your idler arm and see if it is shot
Old Sep 2, 2007 | 10:26 AM
thook's Avatar
It may be just laying an egg. They do that from time to time. And they hate being lifted when doing so. It's also possible when you repaired the CV the c-clip/retainer on the axle stub didn't stick. That's happened to me before.
Old Sep 3, 2007 | 09:16 AM
well i didnt repair anything yet, just trying to get some help diagnosing the problem...is there a kit that lowers the front diff, because it looks like the axles are stretching down after the lift????
JNapolitano
Nov 14, 2019 07:46 PM
Corvoid
Dec 11, 2015 11:21 AM
Davebarbier
Nov 3, 2015 03:28 PM
JPV
Sep 28, 2015 03:15 PM
93RedKrawler
Sep 25, 2015 04:03 AM
