Bad sound in 4wd....HUBS?
Old Aug 29, 2007 | 05:05 PM
Tacoma750's Avatar
Took the pickup out to pop its wheelin cherry ;-) She did GREAT! BUT...I have a small problem. When I engaged the front hubs/4wd (Pretty new WARNs) and drive it, it makes a horrible grinding/binding sound. Cant tell where its coming from. Almost sounded like its coming from under the cab, but im unsure. As soon as I dissingage the hubs/4wd, it goes away. And just so you know what I put my truck through....
Old Aug 29, 2007 | 05:53 PM
waskillywabbit's Avatar
Put it up on stands and in 2wd and lock the hubs and spin tires. Check for noise. If so then it is in your hubs or front axle. Check it in 4wd with the hubs free. Otherwise a u joint in your d shaft.
Get some Aisins and ditch the inferior WARN hubs.
Old Aug 29, 2007 | 06:14 PM
Tacoma750's Avatar
I know..The truck came with WARNs, I didnt install them. Thanks for the tips wabbit. Always good for info!
Old Aug 29, 2007 | 06:19 PM
baseballchamp157's Avatar
Either that or you just need to greese the hubs. just a sujestion
Old Aug 29, 2007 | 06:21 PM
Tacoma750's Avatar
Im new to IFS..Im used to working on dana44s under my Wrangler ;-) I need to learn how to maintain the IFS setup..and how to keep it greased.
Old Sep 2, 2007 | 04:38 PM
bry-an's Avatar
grease is easy
well its pretty simple in terms of greasing... just make sure you do it pretty well every time you go through deep mud water or really dust areas.
on the driveshafts every joint except the double cardans (where the front driveshaft enters the transfer case) gets lithium grease and the double cardans get moly keep the slip yokes greased and the u joints maintained as well as checking the ball joints occasionally and you should be good. if your bad sound is under the cab its probably a u joint jack up the front and try to spin the front shaft by hand and see if it binds, also look to see if the ujoint cap is popped off
good luck , and nice rig!
Old Sep 2, 2007 | 04:55 PM
bry-an's Avatar
ok here follow this link and go to the greasing section... i thought i remembered readnig this somewhere... http://www.4x4wire.com/toyota/maintenance/front_end/
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
yourrealdad
Jul 21, 2015 11:13 AM
PlayAwhile
Jul 20, 2015 11:36 AM
