Tricks for tapping in the front cam seals?
Old Aug 29, 2007 | 02:15 PM
snelson's Avatar
hey guys,
Do I need to go out and buy the SST tool for tapping in the front cam seals on a v63VZE? Any tricks/suggestions on how to seat these properly without using SST tool?
Steve
Old Aug 29, 2007 | 02:20 PM
Duncan92sr5's Avatar
Get a big socket with the same OD as the cam seal and tap it in...No SST required
Old Aug 29, 2007 | 02:23 PM
snelson's Avatar
Awesome - thanks Duncan - I also found from another post the following info - (tried to search before I posted but didn't see anything at that time)....
You can tap in the seal with a socket, piece of pvc pipe, or anything of same diameter. I just lightly tapped around it with a ball-peen hammer. The important thing is that it goes in evenly and flush with the inside of the cap and journal. Also, it does have to be well lubed, but not overly. The way you did it is fine, although I would say the other way is best. Just have to make sure it seated it in well and it didn't bind under the cap when you torqued it down. But, you will want to pull it and lube it...which means you'll have to go back and remove all the bearing caps sequentially just to get the end caps off to pull the seals without damaging them. Then, I would put back it the "accepted" way.
On the valve covers, where are the places it mentions?
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
razorman8669
Jul 12, 2015 12:13 PM
