- 1986 4Runner Hesitation/No Power
- Help diagnosing coolant leak? 92 Toyota pickup
- Is my 4runner toast? W/pic
- Intro Newbie
- Dang ol 3vz
- Missing connector & catalyst
- 1st gen 1987 kickdown trans cable. 22RE
- Overheating... Again...
- Mystery cut wires! Please help ID
- Issues removing horn relay ('95 Pickup 3vze)
- Engine vibrates, runs rough
- Thinking it’s the fuel pump
- Windshield wipers 180 degrees off 94 Toyota PU
- Front and rear swap from 91 to 87
- 94 -22 RE chain tensioner
- Dually brakedrums Itasca motor home
- 2nd Gen Runner, Rear Diff Gasket Leaks a day after installation
- New P/S Pump Leaking Slightly
- 95 4runner Automatic trans, will only move in 4L
- Behold! A secure external tailgate window switch
- Leaf springs plates/brackets?
- Alternator Brands
- in desperate need of motor mounts
- Puddles of ATF in my vacuum hoses. Dead ACV?
- Axle Splines in a 95 4runner diff.
- 22re running rich, slight oil in the intake manifold.
- Motor mount bolts
- What is a 1-ton?
- What is a 1-ton?
- What is a 1-ton?
- clutch won't build pressure
- Stock 1993 pickup 2jzge swap
- 1986 4Runner w/ OM617 Diesel Swap
- Stock starter 95 Toyota pickup pre taco
- Another Cold Start Injector question.
- spraying radiator cap
- 22re vacuum hose size?
- Alternatives to stock fuel line crush washers
- 93 3vze missing and speedo intermittent
- Remove aftermarket cruise control
- 3VZE CS Performance Injector Replacements
- Pinion angle on shackle lift?
- I'm lost
- Just like my username, when it runs it runs
- Smoking brakes---right front wheel!
- Tune up time.
- Fuel tank for 87 4runner with 20R
- 93 4runner correct torque converter help
- Recognize these shock hoops?
- Brakes keep shaking - and my repeated failures to fix it
- What year?
- 3vz alternator and battery issue 94 pickup 4x4
- 90 pickup adding power steering
- Windshield Wiper Motor Replacement 94 PU
- 92 pickup stalling and shutting off.
- I need some help figuring out a timing issue with my 1986 Toyota 22r pickup.
- nathan buchanan and autoshop101; what happened?
- Setup DRL on 92 Pickup
- 1986 22r cab swap to 1986 sr5 22re cab
- 91 22re pickup having idle issues when warm
- Brakes trigger Turn Indicators...
- 95 pickup auto transmission won’t shift
- Best adhesive for door panels
- 98 4runner samurai swap.
- Battery & Wiring
- Injector controller?
- Key reminder buzzer location?
- Looking for manifold union. Discontinued? Other options?
- Does anyone have pictures of wiring going to starter?
- 1995 4Runner Instrument Cluster bulb wattage
- Does a 1995 Manual 4x4 4Runner have an oil idiot light
- 1986 Toyota Pickup - Stereo Wiring
- Shifter stick
- V6 5-spd missing piece?
- Shaking / Vibration after 3rd member rebuild
- Identify this lift kit
- 3vze injector problems
- A340H Transfer Chain Case Oil Weight
- 22re code 11
- 1988 22RE ignition switch plug pin continuity test check?
- 93 Toyota gas tank, larger
- Will a mad blaster help me much?
- Ac Issue
- Best rust inhibitor?
- '88 22RE 2.4L 4x4 Toyota Thermo Time Switch
- 93 4Runner Rear Brake Drums and Shoes - Adjuster and One Drum Not Coming Off
- Restoring/Repairing Thread On Fiberglas
- Buying a 1995 4Runner
- 1988 3.0 auto need help pls knock sensor? Ps I’ve searched
- 1989 truck V6 3.0 EFI 3VE-Z motor identification
- 93 4Runner Hub Studs broken PLEASE HELP!
- 4 runner 91 v6
- Tranny install, 3vze, m/t
- 85 22r into a 94 chassis
- Spacing between upper control arm and bushing/housing
- Super weird head
- I'm looking @ a 1991 Tacoma/is this a good deal? W D Y T?
- 1993 Winnibago Warrior / 93 toyota pickup 22re
- Question about 93 4Runner cigarette lighter socket
- Pulling 3VZE without heads
- Transmission takes a long time to up shift from third Gear!
- 22re bucking, hesitating just need to turn off and start it back up to fix
- Looking for transmission shift base oil baffle ?
- 1990 pickup 4x4 3vz3/a340
- Random Rattling
- Tell me how my t-case position sensor was bypassed.
- 1986 22r suddenly stops running
- Anyone have real success wth sound reduction?
- Replaced u joints, all my markings got erased and now I have constant vibration.
- Sealant for rain gutters and fenders
- 86 4Runner - electrical issue
- Rust removal on body
- Truck Configurations
- transfer case mount
- 1990 3.0 auto to 5 spd swap
- Can you tell from this picture which transfer case this is?
- 22RE Knock Sensor mount completely missing on new block?
- 91 Toyota pickup
- new to me 1989 3VZE 4x4 with A340H - no start, wiring challenges
- gas leak under intake manifold
- Firewall passthrough 87 Pickup
- 93 22re 2WD
- Exhaust Manifold
- What transmission do I have?
- 22RE Intake Manifold Differences?
- How specific do you need to be with wiring harness part numbers?
- OBD-1 and Open / CLosed Loop hom to control?
- 1987 Pickup Dome Light Issues
- 92 4runner stalling and backfiring
- Fast Idle Non Existent on 86 Truck
- Off and on Vibration in the steering, while driving and, while coasting
- Thrust washers scored and mashed
- 1993 3.0 v6 sr5 pickup
- Front End/Steering/Suspension a
- Virgin head and rocker arm issues
- 86 22RE-T Start Problem For 3 years now HELP !
- Vacuum components & diagram for 1993 22RE California
- Which Torque Converter is Correct?
- First accident in the '87, what am I gonna have to look for?
- No start after new Fuel Pump- 3vze
- Rear lift
- Help tracking part number
- What's This Dongle Hanging Near the Throttle?? VSV?
- 89 to 92 Front Grill Conversion
- Need some info for BIG 3 upgrade
- My 1st complete rebuild on my own, at 235,000 miles. Not as hard as you might think
- Rebuild, from standard size piston to 92.50mm +20 oversize
- IFS Ball Joint Spacers
- Evap issues and where is the BVSV and what does it look like
- '94 Toyota 4x4 differential pinion solid spacer help needed
- Help with Seconday Ignition Scope Analysis
- Identifying a hose
- Transmission Noise
- 22RE Valve Seal Replacement Questions
- 3vze orange top fuel injectors
- Timing retards briefly before advancing 95 3-VZE
- Engine Clacking, possbilities before I tear into it?
- Radiator Fan
- 92 4Runner 3.0 VZE Leaking Hoses Need Help Identifying
- Temp Gauge Erratic 89 4Runner
- Identifying Coolant Hoses
- Front differential advice
- Very Weird Intermittent Braking Issue, 91 Hilux
- Front differential pinion seal replacement and preload check
- Do i really need to spend $2900? '93 truck
- Help identify this part, 89 4runner?
- 22re backfire/rough idle
- '88 sr5 3.0 4runner Needs an Intake hose
- Are Torsion Bar Anchor Bolts Interchangeable (pre-1988 bolt is discontinued)?
- '93 3.slow idles a while and then dies.
- 92 4 runner no power to brake fuse in fuse box
- Low Temp Gauge
- Cell phone holder
- 1994 3.0 Truck Advice.
- 2nd gen 4runner oem window visors?
- 1995 spark but no start
- Front diff bearing
- 89 Pickup sitting for 10 years
- replacement fuel tank 2nd gen
- Double Roller balancer
- 1990 22re manual transmission gear oil
- motor swap
- Bright Headlight indicator
- Reupholster Seats lets see um
- 4Runner Hardtop on Toyota Pickup
- Seat compatibility
- Timing belt queation
- 1994 Toyota Pickup Alternator
- 89' Pickup build
- 1993 4runner lift issues
- Am I getting screwed?
- 1989 truck 22r
- R-134a Conversion - How did it work out?
- Where do vacuum advance hoses go to?
- Separate Transmission from Bellhousing
- Injectors
- I need advise on refreshing a 1989 Toyota 4x4 pickup suspension
- Leaf Spring recommendation for '89-'95 xcab 4x4 pickup
- Advice on Painting Canopy
- 22re will not reach operating temperature - Noob
- High pitch sound
- 1988 3.0 auto need help pls newbie!!! Lost power
- 1990 5 speed 3.0
- 1990 5 speed 3.0
- 1990 5 speed 3.0
- 22re Deisel rattle noise, runs rich, burns oil
- Frame damage and vibration
- What is this mystery wire and the "box" is powers?
- Seeking 92 Toyota 4Runner 3.0 advice
- 22RET injectors not firing!
- The 5th/cold start injector always getting power?
- Random hanging wire by oil filter
- 94 4runner 3.0 engine ticking noise help
- Eaton truetrac with A.D.D?
- Sunroof for a 86 sr5 extended cab
- Where do vacuum advance hoses from distributor go?
- Is my truck overheating?
- Loud rattle and marble sound coming from bellhousing after clutch/flywheel job
- 22R which install order: Timing Cover or Oil pan?
- 1989 4Runner Restore - Some Questions
- Correct Replacement A/C Suction Hose for 1994 Toyota Pickup
- Coolant temp gauge reading wrong
- 1990 22r start won't idle and run help!
- 1990 put with 92 22-re converted with a 1990 carburetor starts won't run
- I think I messed up honing my cylinders
- 3.4 and 5 Speed Swap Questions
- 1986 Pickup Kickdown detent cable
- CSF 2314 Radiator Review
- Bellhousing Compatibility
- Truck kinda dies in heavy rain
- 86 Motor 88 Engine Bay Wire Harness??
- HELP 1986 1 Ton Dually Driveshafts to short
- Body part recommendations
- replace fuel line 1987 4Runner DLX 22RE
- Brake issues
- 1994 yota ifs lift with 35s
- 87 DLX 22RE fuel smell and starting issue
- Dual Case Adapters
- New Denso O2 sensor doesn't fit.
- Help me identify a part
- Why are the OEM Denso oil filters so cheap?
- Wiring
- 22re Unusual hard start help?
- Does this sound like a BHG? (22RE)
- 22re igniter swap
- 93 4Runner Driver Side CV Axle
- Ignition Key lock
- Loose/rattling camshaft causing misfire?
- headlights on buzzer
