3vze injector problems
Old Oct 14, 2020 | 03:03 AM
Micmat's Avatar
Hi! just bought a 94 Toyota 4Runner with a v6. Have had problems with it from the beginning. sylinder number 5 is filling up with petrol completely, to the point where I can't even crank it. I´m pretty sure the cold start injector isn't the problem, which only leaves the injector, right? I have changed all the injectors(bought from eBay), sparks plugs, spark plug wires and checked the distributor cap. all looks good. Where are the injectors connected to, the ecu? or a separate controller? I´m wondering if it's just constantly spraying fuel in the sylinder. if the engine stops cranking, I remove the spark plug and empty the sylinder, then it's able to crank again, which means it's only in that one sylinder. anyone got any ideas?
Old Oct 20, 2020 | 07:10 PM
thook's Avatar
possibly ecu injector driver circuit. easy enough to test. there are manual links posted in the stickies on the front forum page that should have the info. otherwise, someone around will help with that i'm sure
Old Oct 21, 2020 | 05:59 AM
Micmat's Avatar
I could not find anything on testing an ecu injector driver circuit on the front page, do you possibly know how to do that or maybe you can post a link as to where I can find it? thanks!
-Mike
Old Oct 21, 2020 | 07:01 AM
scope103's Avatar
It's not the ECM. The ECM opens all 6 injectors at the same time. If the injector circuit was stuck on, you'd have a problem with all 6 injectors.
It's possible you have a leaking injector. This isn't too hard to test; easier than replacing injectors for sure. Remove the plenum, replace the fuel return line temporarily with 6mm (1/4") hose, slide 1" wide strips of blotter paper (?! I had to use ordinary typing paper) down the runners so they sit under the injectors. Pressurize the rail with FP-B+, count to three, pull out the strips and look.
Originally Posted by Micmat
... I have changed all the injectors(bought from eBay), ...
Aaah ....
Old Oct 21, 2020 | 07:07 AM
wallytoo's Avatar
Originally Posted by scope103
It's not the ECM. The ECM opens all 6 injectors at the same time. If the injector circuit was stuck on, you'd have a problem with all 6 injectors...
https://www.yotatech.com/forums/f116.../#post52452575
Old Oct 21, 2020 | 07:35 AM
scope103's Avatar
ya-know, I thought I had seen that posted here recently.
Old Oct 21, 2020 | 08:39 AM
wallytoo's Avatar
you did. and like you, i get annoyed by multiple posts by the same person asking essentially the same question, although i guess i get more annoyed than you do. it's all good.
travisamorgan
Dec 23, 2013 09:38 PM
chevyguy1982
18
Feb 5, 2012 11:37 PM
budro
Feb 23, 2010 01:43 PM
va slim
Oct 26, 2009 04:26 AM
SalmonRiver1
Dec 3, 2008 05:58 PM
