22re Deisel rattle noise, runs rich, burns oil
Old Sep 11, 2020 | 09:53 PM
carlost9322re's Avatar
I’ve had a 93 22re with 175k on it for a couple of months got it at 169k. Since I got it It makes a deisel rattling noise for about 2 seconds on startup, it idles fine around 1700 and then drops to about 900 when warm.
It’s running pretty rich with a strong fuel smell from the exhaust. There is also a diesel rattle noise that happens when lightly pressing the gas and when letting off the gas but doesn’t really happen when I step on it.
The Diesel rattling sound hasn’t gotten any worse over time it’s not that loud. Never idles rough. Burning hasn’t gotten worse. I don’t feel like I’m losing power and the rattling doesn’t get worse under load.
Old Sep 12, 2020 | 11:00 AM
Co_94_PU's Avatar
Rod bearings are the noise you are hearing, it's due to worn bearings and/or low oil pressure.
Old Sep 12, 2020 | 02:33 PM
Okay so the oil pressure gauge is not connected the wire is broken. I might have to go on a little road trip with it.
Old Sep 12, 2020 | 04:48 PM
Co_94_PU's Avatar
What i was trying to say is, Guage your bearings, measure the oil pressure, maybe switch to a different oil filter, check the tolerances on the oil pump.
Shananigan
May 8, 2014 09:39 AM
HairyTheWombat
Jul 13, 2009 01:12 PM
Kiroshu
May 25, 2009 07:39 AM
Toad555
Jun 13, 2006 05:10 PM
oseas
Feb 8, 2006 06:42 AM
