PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 [262] 263 264 265 266 267
  1. 3vze Defect Summary
  2. Fender Flares
  3. manual hub hardware part#'s
  4. HELP ASAP!! Need some quick info for 22re.
  5. question about my truck. *code 71*
  6. how do you recognize bad wheel bearings
  7. Truck is dead...but it isn't...
  8. vibration in front
  9. Replacing sliding windows on shell
  10. SR5 Gauge Cluster
  11. Pwr Steering bleed valve on Steering Box ?
  12. 4WD flicks off...
  13. Anyone pulled the carpet and put rhino on the interior floors?
  14. Swamping out 4" Lift to a ???
  15. Just installed a new cat and flowmaster muffler
  16. Keep my874runner and build it, Or buy my96landcruiser?
  17. Just picked up a 91 4runner
  18. Installing Aisans tomorrow.. anything I need to know?
  19. 1994 Pickup FSM manual
  20. "4wd" light randomly comes on. Why?
  21. 94 Yota Pickup, 95 Suzuki Rf600
  22. 1989 Toyota pickup "HELP"
  23. tranny swap
  24. Pickup impresses Jeep owning roommates
  25. 22re 85 vs 86
  26. New 1990 SR5 V6 owner and BIG problems
  27. 1st gen glove compartment all crooked
  28. Ok so its NOT the headgasket...
  29. 3vze startup problem
  30. oh man this baby is 90 miles from me! should I buy T4R #2?
  31. Hole in heater controls!!
  32. 2-Door 4runner
  33. Medium Or Heavy Duty OME Springs?
  34. 50 shot of Nitrous oxide
  35. The 3.0 build-up thread
  36. Crossmember torque specs/.
  37. did i get a good deal?
  38. Alignment Issue - 4Runner pulls to the right
  39. Cant keep fluid in radiator
  40. Throttle position sensor installation/setup
  41. Vacuum routing for idle up @ power steering
  42. IFS upgrade
  43. shifter button stuck
  44. who has factory lsd?
  45. Cast Rings in Reman Long Blocks
  46. Does overfillin the tranny w/ fluid hurt the tranny?
  47. Got new Muffler- how do I remove the rusty bolts?
  48. Long Blocks - common to get mis-matched?
  49. Help Replacing Starter(90 4Runner)
  50. Pwr Steering Reservoir Leak..Help !!
  51. Towing a 90 4Runner Auto w/out Trailer
  52. Odometre not working properly.
  53. Clicking noise from rear end?
  54. Oil pressure sending unit replacement....pic.
  55. Sagging rear suspension......pic!!
  56. Ticking noise in 22RE - guides, valves...?
  57. Mechanical Help Needed 94 4 runner
  58. 4 runner back door glass????
  59. which idler pulley is this?
  60. The mystery transmission noise!
  61. toyota emblems
  62. Power Windows help
  63. diagnostic ?
  64. Where is the EFI main relay?
  65. Will 100 series LC springs fit the 2nd gen?
  66. Code 21
  67. Door panels and clips
  68. 63" Chevy Spring Sag?
  69. testing coil w/ ignitor
  70. How often will bad Headgasket cause block problems?
  71. 87 4Runner troubles rolling both side wide windows down...
  72. 95 4RUNNER Gurgling sound
  73. S2S Tuning 3VZ-E Cam Disscussion
  74. my brakes squeek...
  75. Marlin Crawler Ceramic Clutches & Tundra brake upgrade for 3rd gen P/U?
  76. tick-tick-tick
  77. silicone
  78. shock boots or no shock boots?
  79. Good front bumper for 90 4Runner
  80. 1990 4Runner vs. 1993 T100
  81. Are 1st Gen & 2nd Gen Power antennas the same? and other misc.
  82. Is There A "Magic" ECU For a 3VZE?
  83. This is a 22RE right?
  84. Will a 3VZE alternator directly fit into a 22R-E?
  85. speedo bug
  86. hella dual air horn
  87. aussie locker in stock 4cyl housing.
  88. need help woth gearbox
  89. A/C faceplate interchangability
  90. ebay clear corners quality
  91. Timing Belt Quirk!
  92. Am I on Drugs? TRD Headers for 2nd gen 4runners/3rd gen pickups?
  93. Diff Gears
  94. Warn Bumpers...?
  95. OME torsion bar q's??
  96. Marlin Crawler Flywheel has a pit in it
  97. Height, Width, Dimension Thread
  98. 4cyl or V6 instrument cluster? How to tell?
  99. What did i break?
  100. Help Wiring Gauges
  101. Engine removal tips
  102. Can bad Cat cause engine to run hot?
  103. Think I messed up my engine
  104. Detroit True Trac LSD
  105. Airbox Mod.
  106. My match up marks for the front diff and propeller shaft are missing... help please
  107. 2nd Gen FACTORY Paint Colors. (kinda I newb question)
  108. Question About a Possible Donor Truck
  109. Question?? 95 4runner oil leak
  110. Piston ring order
  111. Finally found a HILUX surf for sale in canada....need input!!!!
  112. Gas Tank problem
  113. Is the 22RE that gutless??
  114. #4 isnt firing on my 22re.
  115. 2nd Gen DRL disable revisited
  116. Swap Base to SR5 buckets & Console Question
  117. Looking for stainless fenderwell trim 2nd gen
  118. Rear lift???
  119. exhaust/muffler exchangability...
  120. Deck height and piston size of the 3.4?
  121. Super Clutch vs. Centerforce (or any other mfg, for that matter)....
  122. My yota problem
  123. auto diconecting differential problem
  124. Cracked exhaust manifold??
  125. rednecked ISR mod
  126. coil springs
  127. Valve cover gaskets
  128. *clank* on startup and when too warm
  129. Shock Length to But for Lift
  130. Size and Type of Shackle?
  131. third member skid plate
  132. What's the best repair manual for an '87 4runner?
  133. Volvo electric fan install
  134. tchain cover installation gasket sealer q'stion
  135. 3vze spark plug vibration/ticking noise
  136. Starter Troubles when cold
  137. rebuilding 22re...valve spring & cam question..
  138. All Pro Parking Brake Woes
  139. Need a favor.. How big are the bolts in Aisan hubs?
  140. Would you buy it?
  141. What details to look for, before purchase?
  142. 3VZE dyno baseline before turbo
  143. EGR Removal On 22re
  144. 24 valve heads for a 3vze and 80 extra Miles per tank?!
  145. Motor installation
  146. Hub noise (nasty!)
  147. e-bay engine rebuild kit for my 22re???
  148. Timing
  149. radio installation
  150. V6 or 22re?
  151. cowl induction hood
  152. Engine SWAP - SBC
  153. My timing chain looks good....... right?
  154. HELP 94 4runner tranny problems
  155. 95 4runner rattle noise at about 20mph?
  156. Can I replace 22RE with a 22R?
  157. automatic to manual tranny swap
  158. can i use the 1.5 thk trans cooler in a 94 runner?
  159. New 4.88's are awsome
  160. Anyone eliminate the Clutch Start Cancel button?
  161. winch with stock bumper??
  162. 3vze starter issues revisited
  163. 89 4runner; distributor/igniter problem?
  164. Problem that needs solving '95 4 runner
  165. tire sizes???
  166. wut kind of puller??
  167. flowmaster hushpower 2
  168. What else could cause loss of coolant?
  169. New engine noise (not valve tap or chain rattle)
  170. New guy, first time 'Yota owner
  171. deep oil leak
  172. Diesel conversion underway
  173. Cruise Control Question...Auto Tranny Truck
  174. Another blown Headgasket!!
  175. ADD to Manual Hubs
  176. 92 pickup w/ 3.0 stalls when stopping
  177. Running Rich When Cold---3VZE
  178. Anyone from Concord, OH with a 3.0?
  179. Idiling problem after tune up
  180. 2nd gen 4Runner Powertank mount pics
  181. Anyone know what this valve does?
  182. Lookin for Nerf bars for 88runner
  183. 22re head Suggestions
  184. Coolant leak; 3VZE; backside of engine compartment
  185. 3rd member - rebuild or buy salvage?
  186. Best shocks for stock
  187. cant get it started
  188. Aftermarket steering dampener - related to 50N recall
  189. Front side sagging
  190. Where to get V6 for 88 4x4 4 runner?
  191. Towing 3,500lbs with V6 past 100K mi...crazy?
  192. slipping only in 4th gear??
  193. Newly Rebuilt 22RE major oil leak, and loss of power
  194. 89 3.0 ticking, and now a new rattle
  195. Heater controls have no back lighting?
  196. shocks
  197. Where to go with my truck?
  198. Fuelpump question.
  199. Clickity Click Click, make it stop!!
  200. What kind of shocks are these?
  201. 4x4 working intermittantly
  202. Stubbs Sliders installed...with pics..*phew*
  203. Stubbs Sliders FINALLY installed
  204. yet another rear window question!
  205. Recall for 2nd Gen 4Runners.....
  206. please help with stop lights
  207. 33's on 86 4runner
  208. Truck steers irradically in 4wd
  209. sway Bar End Links - stabilizer bar link - please clarify
  210. Ticking noise
  211. Low Idle - '86 22RE Pickup
  212. Proud new owner of an 87 turbo! PICS INSIDE
  213. exhaust crossover pipe removal
  214. A couple of questions on my 2WD
  215. Oil Pressure Fluctuations! Help please!
  216. Fixed my starting problem.
  217. K&N or AFE?
  218. How are Cigarette lighters fused?
  219. 91 4runner shocks replacement
  220. LSVP height
  221. Sorting out 3.0 exhaust variables & components; report your expiereinces and opinions
  222. Need Help finding parts...
  223. How would you like a Multi Layer Steel HG for your 3.0?
  224. 3.0 valve seat question?
  225. Neep help on u-joint removal.
  226. Does Airfolw Throught The Evaporator Get Restricted?
  227. 90 4Runner steering link recall
  228. will i need longer shocks?
  229. blower motor switch help
  230. Any tips for wheeling a stock truck? (crown king, AZ)
  231. CV axls
  232. 91 4runner keyless entry
  233. Solved Code 71 - EGR VSV!
  234. 3rd Gen Double Cab
  235. worse mileage on highway
  236. Increased preformance on 3.4 5vzfe
  237. i was just thinking
  238. 3vze power option?
  239. OK to only lock one hub? What say you?
  240. add relay/fuel pump relay
  241. Rebuild or Reman'd engine?
  242. revving oddly
  243. toyota 4runner AFM
  244. rear mud flaps - on or off?
  245. How hard is a 3.0 rebuild??
  246. Would I trade the Flamedtruck for an FJC
  247. '94 4runner Predicament
  248. questions bumpy 1993 4runner
  249. 91 AFM vs. 95 AFM
  250. White plastic screw on 22re tb?
