87 4Runner troubles rolling both side wide windows down...
Old Jan 31, 2006 | 04:07 AM
Spark-e3's Avatar
87 4Runner troubles rolling both side windows down...
This is really pissing me off. Every time I roll down the drivers or pass. window in my 87 4 Runner the rubber window seals that the glass runs in is pulled out of the window frame at the top. Usually from the rear first. I only get the window rolled down about 6" before seal comes away from the track on top. I suppose I could glue the damn thing into the upper track but is that the only way to correct this problem? Is anyone else dealing with this problem? Is the fix installing new(if avail) rubber seals?
Thanks a ton in advance!!
Kirk in Oregon
Old Feb 2, 2006 | 02:32 PM
jposey66's Avatar
I recommend 3M weatherstripping adhesive.
Old Feb 2, 2006 | 02:45 PM
shiftless89's Avatar
replace the window run. you'll apreciate the bennifits for the next 20 years. I did mine, got the parts from trdparts4u.com
Old Feb 2, 2006 | 03:31 PM
waskillywabbit's Avatar
Phil & Chris will do you right.
Old Feb 3, 2006 | 08:03 PM
Tiger Paw's Avatar
I'm having the same problem with my driver's window, except it just pulls down at the back of the window. It doesn't come all the way out. Thanks for the link. I'll be checking them out, too.
Old Oct 6, 2006 | 05:51 PM
swerks's Avatar
part numbers ????????
Old Oct 7, 2006 | 04:24 PM
swerks's Avatar
part numbers Please ????????
Old Oct 7, 2006 | 05:28 PM
replace the window run. you'll apreciate the benefits for the next 20 years. I did mine, got the parts from trdparts4u.com
Call strap22 and let him find the part #.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
coryc85
Jul 7, 2015 04:05 AM
elwood73
Jul 5, 2015 07:07 AM
