Low Idle - '86 22RE Pickup
Old Jan 22, 2006 | 08:17 AM
elmo908's Avatar
I recently sucked water up in my engine, after turning the motor out and fixing the car I have noticed that on some occasions the truck's idle will drop down to the 300-400 RPM area and the truck seems to be running fairly rough. I noticed the air flow meter was corroding from water so I cleaned that out and it seemed to help but the truck has just started doing it again. If anyone has had this experience with their 22RE I would appreciate if you chime in.
Old Jan 22, 2006 | 02:10 PM
Elton's Avatar
did you try turning up the idle screw
Old Jan 22, 2006 | 05:34 PM
84sr5yoty's Avatar
The air flow meter may be on its way out. Click below for instruction to test it.
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Jan 26, 2006 | 06:06 PM
86_runner's Avatar
i did the same thing to mine and it had the same symptoms. Open the throtle body and see if there is any sludge built in behind the flap. But in all honesty its probly in the air flow meter.
sonic concepts
Aug 16, 2025 03:13 PM
Sandman
Jul 23, 2015 08:15 PM
puddlepirate
Jun 30, 2015 05:08 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
