diagnostic ?
Old Jan 31, 2006 | 03:26 PM
86_runner's Avatar
diagnostic ?
I have an 86 4 runner with the 22r efi non turbo. My problem is that I cant figure out where the connector is mounted to perform an ecm scan (to get a code). can anyone help me out. ive checked under the hood by the fuse block and look inside both kick panels and ive had the whole dash out. Does my truck even have a this feature.
Old Feb 26, 2006 | 09:11 PM
soulfly's Avatar
If you have a cel you should have a check connector
Old Feb 27, 2006 | 09:33 AM
Bobakazi's Avatar
You should have a sticker under the hood that will tell you where it is. I use a paper clip to short the circuit.
Old Feb 27, 2006 | 05:07 PM
soulfly's Avatar
If it the same as my 86 I had 22r than I believe you only have the check connector and no diagnostic connector. It was right next to my fuse box on the driver side little green connector if I remember right, and I also use just a paper clip
some drunk guy
Aug 3, 2021 06:09 PM
calderp
Nov 16, 2015 02:49 AM
mulewright
Sep 28, 2015 10:27 AM
charlie_fong
Sep 27, 2015 10:06 PM
Boomer8404
Sep 24, 2015 01:12 PM
