Heater controls have no back lighting?
Old Jan 22, 2006 | 11:27 PM
F0RSAKEN's Avatar
Just bought a '94 T4R SR5, 146k miles, lovin it so far, just took it up to the pass (Stevens Pass, Washington) and had some fun in the snow.
Anyway, as my second n00b post of the week, I searched on 'HVAC' to see what I got, but no one seems to be having a problem, so I assume there isnt one...the heater controls dont have backlighting do they? Or are mine just not working?
Old Jan 22, 2006 | 11:53 PM
Bobakazi's Avatar
They do have a light. Your bulb is out.
Old Jan 22, 2006 | 11:57 PM
Tofer's Avatar
Sponsor
mine worked when i bought it, stopped working when i had the stereo installed, (but moved back down to school before i noticed) and now work again after tearing the dash apart... so tear the dash apart maybe they will come on for you.
Old Jan 23, 2006 | 12:15 AM
Bob_98SR5's Avatar
look in the tech section for writeups on changing your stereo nad you will see the procedure for taking off the face plate to change the bulbs
bob
Old Jan 23, 2006 | 01:37 AM
EWAYota's Avatar
Good to see you joined up, welcome!
My 94 had the same problem, and like Bob mentions, there is a write up in the tech section on how to replace the bulb.
Like I mentioned to you in the PM on the other board, this place has a large amount of info for you and the direction you want to take. Use the search feature as that could be your greatest tool, and be ready to meet some great people.
Old Jan 23, 2006 | 05:01 AM
Buck01's Avatar
basically you pull the knobs of the control levers. use a screw drive to pry the face plate off and then remove the long clear plastic piece and you will see the bulb.
Save the little cover on the old bulb to put on the new bulb.
Old Jan 23, 2006 | 05:58 AM
Glenn's Avatar
Pull the control handles off and use a bent paper clip to carefully pry the piece off. Insert the L of the clip into the slot where the heating vent is and pull out carefully.
Old Jan 23, 2006 | 10:41 AM
F0RSAKEN's Avatar
Thanks guys, went to Schucks, got the bulbs, and replaced the burned out one....then went to 4 Wheel Parts and bought a Red Top battery
Old Jan 23, 2006 | 01:49 PM
da_bigg_wigg's Avatar
ive got a similar problem. my backlight is cranky. works about 20% of the time. it kicks in or out after a bump, so its most likely a loose connection, ive just had no time to fix it.
Old Jan 24, 2006 | 09:05 AM
boriswebs's Avatar
Mine is almost the same as bigg_wigg only mine comes on 5% of the time and it doesnt do it when I hit bumps. Its when I change the heater settings. Its not the bulb because I have replaced it. Itendded up being the wires leading to it that where the problem they got pinched somehow. (previous owner didnt know how to install a cd player messed all kinds of things up)
Old Jan 24, 2006 | 09:19 AM
Epic Ed's Avatar
I've had this identical problem for a few years. It comes on on occasion, so I know the bulb isn't burned out. I have taken the entire dash apart several times to do other stuff -- each time I have everything torn apart I try to track down the short, but I've never found it. Mighty frustrating.
Ed
Jun 1, 2021 01:51 PM
coryc85
Sep 9, 2015 06:24 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
elwood73
Jul 5, 2015 07:07 AM
