Tie rods?
Old Jan 17, 2006 | 09:28 PM
CoedNaked's Avatar
Tie rods?
My ball joints on my IFS are in good shape I know that, the Idler arm is new with idler arm brace, but the steering stops seem to be more "catchy" than the usual noisy when in full turn. They were lubed too. My front tires also seem to have a little bit of play despite the new idler arm. Could this be the tie rods then? OR what other front IFS component would you look at?
Old Jan 17, 2006 | 10:41 PM
Lysmachia's Avatar
You got heim joints???
Old Jan 18, 2006 | 03:44 AM
YotaJunky's Avatar
How is the steering stabilizer? I pulled my OE stabilizer and it was completely broken into 2 pieces.
Troy
Old Jan 18, 2006 | 09:35 AM
i_rifiyou's Avatar
where do you get heim joints???
Old Jan 18, 2006 | 09:40 AM
callmej75's Avatar
This is how I knew my tie rods were shot. Leave the front tires on the ground and shake the tire from front to back while your head is inside the fenderwell looking down at the tie rod ends. If you see play or hear clunking...thats the probable cause.
Old Jan 18, 2006 | 03:01 PM
Lunnzz's Avatar
I can see play in my tie rods when I jacked up the truck I bumped the tire while under it and the tire moved and so did the outer end of the tie rod and nothing else is that the norm?
Old Jan 18, 2006 | 03:33 PM
i_rifiyou's Avatar
i had that problem, my power steering levels were low and the belt was a bit loose, roger brown also states that i use automatic trans fluid insted of power steering, this i did not know. but now the steering is great
Old Jan 18, 2006 | 04:39 PM
callmej75's Avatar
Just look at where the tie rod attaches and barely wiggle your tire back and forth...if the part where the tie rod attaches to is moving but the tie rod isn't moving the linkage at all...its the tie rod. It can go all the way to the idler arm if ya don't notice where its coming from initially.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
beltcutter
Sep 30, 2015 06:14 AM
