Front side sagging
Old Jan 23, 2006 | 11:08 AM
rdimaggio's Avatar
Question Front side sagging
I have a 1992 4Runner SR5 (just purchased) and the right front side is about 1" lower, could this be the coil springs, is that common on 4Runners? I was thinking maybe it was the tires, or shocks?
Old Jan 23, 2006 | 11:41 AM
Bobakazi's Avatar
Is that how it measures when it is level?
Does it have torsion bars? (sorry, not sure if the 4runners had these then. It was an easy fix on my last truck. I just tightened one torsion bar until the distance from tire to wheel well was the same)
Old Jan 23, 2006 | 01:20 PM
rdimaggio's Avatar
not sure.
Old Jan 23, 2006 | 01:22 PM
Fix_It's Avatar
yes it does just crank it till level . common .. would recommend new torsion bars anyway .. mine went dead on our 94 rides much better .
Old Jan 23, 2006 | 01:31 PM
rdimaggio's Avatar
okay, I am mechanically inclined, but can you post a pick of this torsion bar please?
Old Jan 23, 2006 | 01:35 PM
rdimaggio's Avatar
is this what I need to do: www.off-road.com/toyota/tech/torsion/
Old Jan 23, 2006 | 02:50 PM
Bobakazi's Avatar
Exactly. You might have to jack it up, tighten the nut, set it down, and measure it a few times to get it right. Easy fix, and free! You can even tighten it more if you want, then tighten the other side to match for a little more height in the front. Hope all goes well!
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
