PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. CV axle grease
  2. paint before new tires
  3. 1992 Toyota 4Runner Engine Code 42 (VSS Circuit)
  4. 22RE runs rich after 3000rpm
  5. Is this transmission issues? Any advice?
  6. Check Engine Code #6
  7. 1992 Toyota Pickup restoration
  8. ABS '94 4Runner
  9. 1994 3VZ-E 4Runner no start (I KNOW!)
  10. 22re diagnosis help
  11. 1994 Pickup 22R/E no start
  12. 22re MAF Problem
  13. Fitting new Marlin sliders. Please gimme pre-weld feedback!
  14. Random no start
  15. Body shop in Oregon
  16. W56 Transmission Help
  17. 22r Bogging
  18. Pickup Model Classification
  19. Timing Chain Kit Recommendation
  20. 86 Commercial cab/chassis upfitters frame drawing?
  21. 1st gen 4runner nerf bar
  22. 1988 4runner
  23. Adding AC on a non AC 1988 Pickup (Looking for Donor Truck)
  24. Are new OEM tail lamps made in Thailand?
  25. Emissions computer
  26. Wheeling North New Jersey
  27. Good source for OEM parts. Need a new speedometer cable.
  28. How difficult is it to remove an axle shaft on a 4X4?
  29. Charging gauge running on the high side
  30. 22r Acceleration Issues
  31. GM HEI Ignition Swap - Spark Plug Gap
  32. Need some help with older Toy clutch choice.
  33. 94 pickup 12v problems! Need help!!!
  34. 94 3vze problem child
  35. ‘95 3.0 V6 hard starting and won’t pull
  36. Help Identifying this connector
  37. 3 Yotas hit the trails!!!
  38. No fuel on 22r
  39. 89-95 Cut Out Flares
  40. Lock keying kit for 1st gen 4runner
  41. 22r not getting fuel
  42. 92 4X4 Auto Truck 3.0 no power What to check next?
  43. cracking sound sharp corners
  44. Tricky Idle problem
  45. 3.0 engine removal help
  46. Fuel Pump Sending Unit - 1991 Pickup 3.0 4x4 SR5
  47. Bucket seats vs Sport Buckets - 1986 SR5 Xtracab
  48. 94 3vze head gasket question
  49. 93 3vze gas mileage and possible misfire
  50. 30A AM2 Fuse Keeps Blowing
  51. No start, fuel injectors not fireing.
  52. Clutch isn't fully disengaging
  53. Uneven ride height 95 4Runner
  54. 1987 Toyota Pickup - 22r - No Spark
  55. 2nd Gen 4Runner Questions
  56. 8822re
  57. 86 auto tcase fluid?
  58. 1990 long bed measurement
  59. Brake lights staying on with key in on position
  60. changing transmission fluid
  61. Rear wheel ABS actuator hose..
  62. 1993 Toyota 4Runner 3VZE Motor Mount Trouble..
  63. Stolen 86 Pickup- Recovered
  64. Heater control valve cable replacement 92 p/u 2wd
  65. 3vze 93 4Runner distributor wires
  66. Swapping TG main leaf out for rear main leaf fix shackle angle??
  67. 1988 pickup fuel problem.
  68. Toyota 3.0 4wd fuel milage
  69. Power to Manual window swap
  70. replace piston rings with head gasket repair?
  71. Radiator Question
  72. Flat bed conversion weight Opinions needed.
  73. 91 4Runner tire size
  74. Code 24 and 31 help me 3.0 95 runner
  75. Lift for 93 4runner 4x4
  76. Heater Core Hard Line
  77. ECU pin trivia
  78. Funny noise, drive train, tranny/clutch related
  79. 87 Pickup - HEI GM SWAP
  80. 1992 Toyota pickup won't run
  81. Intermittent misfire / bogging / stalling 22RE
  82. Hardware (bolts) for rebuild.
  83. Hesitation in acceleration rpm less than 3500
  84. New Cylinder Head Castings
  85. Breather
  86. 1986 4Runner 22re EFI fuse short
  87. Not going into 4th gear
  88. Gas Tank
  89. manual vs auto ecm identification
  90. ‘89 4runner 3vze no spark
  91. Turbo 3vze
  92. 3vze oil change
  93. 1995 SR5 Horn does not work
  94. Wiring to Battery
  95. Adding second gas tank
  96. 88 RE Vacuum diagram/pics? (Calif, 4WD, MT)
  97. 1987 Toy pickup xtra cab 2wd turbo power steering gear.
  98. Idle and exhaust issues with 86 4wd
  99. 1989 3.0 Oil Soaked
  100. 91' Ody RV Taking off in 2nd
  101. 1988 Toyota Pickup (2WD) 22RE Auto Issues
  102. Deck lamp replacemnet?
  103. 22re high pitched whine (sounds like a supercharger)
  104. Still no spark after replacing distributor and ignition coil
  105. 90 4Runner V6 4WD A/T Intermittent Starter
  106. Air intake question
  107. Battery gauge reading high
  108. New Tail Pipe and Hanger Install Questions
  109. Help! Where does this spring go? 88 4Runner rear brakes!
  110. Motor swap
  111. no fuel?
  112. Warm Start up
  113. cel diagnostic on 87 runner
  114. 93 22RE starts, will run ~ 5 minutes, then die and wont start again for hours...
  115. Tps unplugged?
  116. Engine 3vz 3.0 missfire, Hesitate and surge at RPM < 3000
  117. 95 has no reason not to run after extensive overhaul
  118. TPS Throttle Screw Question
  119. Valve train sounds noise.
  120. gasoline leak from intake tubing
  121. (1986 pickup) Hubs unlocked, but truck feels sluggish
  122. 87 4runner 22re cold start problems
  123. Swap to 5spd manual?
  124. 1988 3vze: hard warm start, engine cut-out, code 11
  125. 89 Pickup Starts then dies
  126. Blow by issues
  127. 22re starts then dies. Again. SOLVED again. Lol
  128. 88 Toyota Wiring/ECU Advice
  129. 87 runner stalls at idle - advanced troubleshooting
  130. 3vz engine acceleration and lack of power
  131. Is there supposed to be a jumper from EFI fuse to relay?
  132. 1986 Climate Control with A/C & Wiring Questions
  133. 95 T100 3.4L Dies after warmup.
  134. Double check transfer case fluid drain procedure
  135. Leak from power steering gear box adjustment screw
  136. gray toyota 92 pickup 2wd paint code 179
  137. Looking for Matching Stripe Decals
  138. need a few reference photos of an 86 EFI 4x4 engine (exhaust and intake) please..
  139. Auto transmission reverse only in 4 Low???
  140. EGR delete bolts
  141. Headers
  142. Newbie here just testing!
  143. leaky headgasket - remachine heads AND block?
  144. 86 22RE 4x4 Electrical Gremlins
  145. 1986 Pickup 4 speed manual
  146. Sputtering issue.
  147. Do you ever start work on som ething and then end up with a whole other project?
  148. 2/3RZ swap oil pan for 2WD
  149. Storaege bag or something for the sunroof cover
  150. 1986 Pickup 22r Cylinder #3 misfire and engine running super rich
  151. Sensor on top of water outlet
  152. Hot start stumbles and dies.
  153. tailgate window will only go up, wont go down unless i press the button like 1000 tim
  154. Connecting tube between fuel pump and fuel line.
  155. Heater Box Reapir
  156. Cab swap options
  157. LSPV bleeder screw broken
  158. 86 head gasket reseal #2 attempt
  159. Rear diff oil SAE 90 or SAE 80w-90
  160. Distributor tower clips?
  161. Finding odd little parts?
  162. Odometer correction
  163. Rear trim makes the window go up slowly
  164. 22re 1st gen dies when warm
  165. 22RE Intake Pipe Radiator Hose Clearance Solution
  166. Valve lash shims
  167. Intermittent overdrive O/D relay bypass fix
  168. Low idle right before thermostat opens
  169. Pickup Won't Start
  170. 1994 2wd rim upgrade
  171. 1994 4 Runner 3vze, 5 speed
  172. 22re OEM 190 Thermostat / Idle drops at 200 Fahrenheit
  173. Best MLS
  174. 1989 pickup RWD swapping to FWD rear springs. Need 4WD shackles for this??
  175. 94 4runner transmission issues and advise needed
  176. Need help identifying correct oil seal for rear transfer case leak
  177. What is this leaky nipple on my transfer case
  178. Forgot Where These Go
  179. Said goodbye to my truck after 22+ years
  180. 22R trouble starting
  181. Help! Changed Gearshift bushings and...
  182. 93 22re cranks won't start
  183. 94 pickup 4wd v6
  184. Broken Electrical Plug On 22RE
  185. Fuel pump issue
  186. Ignition Issue - from a new guy
  187. 1992 4Runner won’t stay idling
  188. AC pulley diameter
  189. 87 4Runner Pass Side Hard Brake Line
  190. 94 4runner totally dead electrically after light bar install
  191. low oil pressure
  192. Weird idling issue California with EGR 22re
  193. HELP 1995 Toyota Pickup 22re 2wd Rough idling, stalling, driving
  194. Aisin Aftermarket Locking Hubs
  195. Restoring 3VZE and A/C in 1991 Pickup.
  196. Blew a sparkplug! 87 4Runner
  197. 1990 Pickup Engine Oil Leak
  198. New 1993 4runner sr5 owner
  199. Fuel regulator hose
  200. The 91 hit the trails in Sussex CTY
  201. Squeeky Belt or ?
  202. Intermittent no start and stumble/bucking
  203. 1994 v6 3.0 auto loss of power, weak all roung
  204. Wiring a Rail II controller
  205. 22RE Oversized Injectors
  206. Are these still decent cv axles? Napa gold
  207. Double cardan joint
  208. Valve seals
  209. '87 4Runner Ignition Problem
  210. 1994 pickup 2wd. No possible history.
  211. 88 3.0 Radiator
  212. 22RE Weird coolant related idle
  213. Weird spherical clumps found in liquid side of Expansion Valve. 1991 Pickup 3.0
  214. 1990 4Runner real wheels will not engage
  215. Stokes State Forest Snow Trail Ride
  216. Where can a man get a stock camshaft
  217. Unknown accessory in a beat up 1989 pickup
  218. Rear bearing issues
  219. Interchangeable parts
  220. Need cold start injection help 87 T4R 22RE
  221. Hi beams aren't working -- at all- on 1985 Pickup
  222. Headlight problems
  223. 1989 pickup 2wd 2.4 overdrive not engaging
  224. O-ring instead of gasket on oil pickup tube
  225. No power to B+
  226. 1986 Restoration
  227. Body Part swap??
  228. 86-95 22re to 2l-t/2l-te conversion
  229. Universal fuel filter
  230. Snow Wheeling!
  231. Blue vacuum switching valve replacement
  232. Code help please
  233. Painting my cluster surround, suggestions/questions
  234. Sporadic cutting out
  235. 1993 Toyota 4Runner Rear Speakers
  236. Whirring noise manual transmission
  237. New Year, New Truck, New Member
  238. Part number for fender flares
  239. 86 horn circuit, can't find the relay?
  240. Front Mud Guards - best place to get?
  241. Broken rear torsion bar mount repair
  242. 2nd to 3rd gen winch bumper fit compatibility?
  243. TAIL Fuse is the wrong amperage.
  244. HELP! pulling codes
  245. CV Axle replacement
  246. Speedometer correction help.
  247. 1987 Custom Cab Rebirth
  248. Replace dash blanks with USB extension
  249. Temp Gauge Flutter (sometimes)
  250. 1990 4Runner Top Fender Bolts and bumpers
