- air box battery swap done, thanks folks
- Rear R&P
- speedometer issue approaching?
- Starter problem.
- Pickup vs 4Runner frt. sway bar
- 94 4Runner Headlight Question
- Exhaust flex coupler?
- 1987 4runner front power windows
- bed 2wd vs 4wd?
- Hydraulic tensioner timing belt
- Need longer brake lines
- HOW BIG of tires on stock suspension.w/o rubbing?
- Gear install source?
- knock sensor torque specs?
- 2" coil spacers
- No Start after compression test
- pullin a pop up with the 22re
- Sold 2nd gen- what now?
- Something is up with my front axle!!!
- aloha, valve lash specs on da 22 re?
- improving my 92 P/U
- First time off the pavement in the 4RNR
- front wheels locking up
- I think I killed 'er
- bad maual steering box
- strange whirring noise
- Ignition problems
- Any performance parts for a 3.slow
- I really hate when I do something stupid!
- Need Photo
- water in the fuel tank
- BullFrog Rust Kit
- New guy looking for advice.
- truck died
- New Carpet
- Spontaneous Truck Fire!
- Lower control arm (LCA) bushing replacement
- power steering pump
- why can't people drive...
- Head Gasket
- What WILL Break?
- Pics of my 91 Toyota
- serious 22r problem
- A little help with a melting fuse please
- new guy/ different build strategy
- ignition cylinder interchangeability ??
- LSPV lift bracket
- I'm goin' in! - 3.0 Head Gasket -tips/tricks welcome
- Power Loss
- Painting Advice
- Reassembly
- York air compressor, 22RE
- skidplate transfer
- New truck couple questions
- what spark plugs should i use..?
- Buying a LockRight
- shocks for BJ Spacers/ Cruiser Coils
- What in the world made my spark plugs....
- came across these guys..check it out
- plz someone help
- Certifit and Parts train
- Help! window problems and its gunna be a rainy week!
- Preventative maintenence for throttle cable
- 80 amp "Glow" fuse?
- How much more until my idler pulley locks up?
- steering adjusty thingy
- Wheel bearing seals, backwards?
- More questions for y'all '86-'95 crowd:4runner and pick up body parts swap.
- TJM-17 wing
- intake-exhaust formula?
- cruiser coils
- Problems associated with Tropical Storm.
- Powder coated bumpers (black hammer tone)
- exhaust manifold torque specs.
- Tires
- brake question.....
- Looking for a carb insulator
- Driveline "whirr" - PLEASE HELP
- Good deal???
- Anyone know a reputable place to get a 3VZE rebuild done in Portland OR?
- Transfer case output seal????
- lift
- passenger side leak !help!
- Drive axles won't come out??
- Thinking of getting a 89~96 ex-cab 5spd 4x4 truck
- Isuzu aluminum rims on pick ups?
- anyone have a starter
- Torsion bar adjustment prob ?????
- what MPG are you geting in a stock 22RE\auto\4wd
- Wheel spacer/Ball joint spacer/ alignment help?
- Fuel Pump Access
- More body damage
- A 3.4 swap is in the near future....
- Ignition is sticking....keyless option?
- 88 pickup feels like its going to stall when idling
- locked and loaded.....
- tranny problems
- 4runner to pickup engine swap
- Spankfest 08
- Rust?
- Steering Gearbox
- 4.0 backspacing rims
- Wheeling woes
- 1st gen 4Runner bed panels
- fuel/air no start mystery help
- Knock sensor and Throttle position sensor .
- 261C/Crawler with factory efi??
- Oil Pressure Problem
- 4x4 dash light quit working
- Check before I rebuild the carb
- Axle removal question
- Oil Cooler gaskets???
- Need help finding a seat!
- 94 upgrade.. lots of new stuff, before and after pics
- Body Lift Shifter Woes
- I Switched my Battery and Air Box Locations
- Would I be safe towing this?
- Summer build/work
- Help with measurements for Demello Sliders
- noise when releasing the clutch
- a/t temp light coming on???
- G58 shifter seat part #
- Reccomend Muffler and Clutch ...
- 2" Lift Help.....
- Pictures of 33X10.5 tires??
- 88 v6 fuel issues.
- HOw TO discharge Air Conditioning
- is this strong enough?
- Power steering pump surgery question(s)...
- Wheeling done, review and question
- dome /radio/clock fuse keeps blowing
- Looking for pics of those with 3 inch SAS setup.
- $15k in mods at once
- Inspect my Steering linkage with my NEW High Detail you tube VIds
- Update on New Engine - :(
- New ported head or new camshaft?
- Where does this wire go??
- Driveline Howl When Letting Off The Clutch??
- Any advice for a noob?
- Finaly new meats
- Help Identify Headers?
- 2 things: Lift plans... and in need of pictures
- Shock Length for Chevy 63s
- How would you run dual Exhaust?
- So After a HG and TC.....
- 1988 truck: stumbling/idle problem
- Will V6 cluster work with 22RE?
- does this look funky???
- Cigarette Lighter 1994 3VZ 3.0
- 4runner trim piece behind doors
- My truck is possessed.
- 93 SR5 and Factory Fender Flares ?
- new shocks??
- Any 1st gen 4runner's with custom sub boxes?
- Panels
- 94' brake question
- exhaust broke need helpppp
- 1993 4runner - Whacky clicking noise
- I want a tach and gear indicator light on my dash.
- 22RE timing chain Q
- 86 4Runner Starting problems. Just clicks
- PCV on the 3.0
- No Start (no fuel)
- Idle bounces....
- WTB: Black Steelies
- 1 new meat
- 3.0 v6 problem for 1st gen 4R?
- shovel, flashlight, fire extenguisher, Jack mounts
- doing a rebuild have a few questions
- questions about these trucks
- New CV's shorter than old ones
- 1990 4Runner...what's up with the 3.0?
- Time to say good bye to my 2nd gen... For Sale, Thanks for GREAT tips and help!
- my '88 yota rig
- First post - major questions already!
- please help..my truck wont start EVERYMORNING
- a gallon of gas for 50 cents???? look right here!!
- Another Exhaust Question
- Rust What ??
- front and rear gears question
- my truck got busted into..need help with alarm install
- mounting a rollbar
- Rear Drum Brake Questions?
- Help "Loud Ping"
- 3 day wheeling trip
- factory straight axle and a 22re?
- Toyota truck or 4Runner???
- 3.0 timing/fuel... HELP
- Low speed Vibration
- Changing Shifter Seat and Bushing
- High pitched noise coming from rear of truck when moving
- 22re stiffner bracket ? little help please....
- need to change the head
- Sorta new paint job
- 3.0 Rebuild
- ***Timing belt? or Distributor?*** guidance plz!
- head gasket 91 4runner
- weber 32/36 with no choke??
- transfercase question.
- Engine mods
- New CV's VS Reman'd
- 50 state legal sticker for intakes
- 4Runner
- holy dry T-case Swampman!!!
- Radiator problems. Can anyone help?
- 93 22re warm start trouble
- installed my 2 inch body lift
- my door wont open from inside...tricky one
- 86 22re ECU wiring does not match pinout.
- How do you fool a knock sensor?? Need some electrical help
- could I get some help with my alternator problem
- On-board Air - Who has it?
- timing question.
- Buy rolled wreck? Or pass?
- Exhaust Setup i have decided on. Any tips or advice?
- Head Gasket stuff
- lean out on 3vze
- LCE 22re complete intake
- timing chain "play"?
- roof rack???
- rear driveshaft yoke Q?
- 3.0 Drivers side head?
- B antenna mounting help.
- Winch Questions?
- egr valve no worky?
- low, low, LOW power
- 91 22 RE missing at idle
- radiator drain plug
- CMH on 92 4runner
- NEED HELP! - Low oil pressure & leaky oil breather
- new guy, which lift?
- tapping/knocking sound.
- 33's on stock height???
- 22re turbo idle prob
- things to do on a car that has been sitting?
- same rattle after rebuild
- Park brake wont lock HELP!!!!
- How to figure milage with 33's??
- 91' 3VZE no crank!!!starter not even clicking
- 95 4runner speedo cable... where?
- Extending brake lines
- lift with stock rims?
- Gusseting sliders
- ok, this truck is starting to piss me off
- need help! 22r not starting
- 95 4runner fuel presser damper?????anyone
- Speedometer cable and cluster problem
- EFI Troubleshooting Question
