- 1993 Toyota 4x4 extra cab Pickup 22re will not start - distributor
- 93 sr5 3.0 v6 starting issues
- Rear axle bearing seating depth question
- need help
- half shaft pops out when in 4wd
- Truck backfiring no power
- 93' 4runner 3vze starting woes
- Dash "Cap" for 88 4runner
- How to test for a saturated carb float?
- Fading brake pedal with engine running, firm without, new master = no improvement
- 89 toyota v6 4x4 won't start
- 91 4runner...should i replace or sell?
- No power to tail light relay.
- 3vze #1 Idler Pully- Spring or hydraulic.....
- Need help find tdc on 22re
- 3.0 head gasket choice
- Who sells tailgate liner?
- 95 3v rear main seal
- Newbie needs 3.0 help/advice SoCal SGV area
- First start up after rebuild/no muffler
- Tramsmisson problems
- What do my compression test numbers mean
- I found a "hide-a-key" under my truck
- 93 3.Slow Acting Up
- ifs axle is crooked.
- Clutch pedal will not depress
- Truck stuck in 4x4 low
- '93 4Runner throwing code 25
- 95 4runner bumper swap
- Is my truck repairable?
- clutch master and slave
- oil blow-back at the dip-stick hole
- Made my own SOFT TOP
- Rusty, Dented, Beater PIC THREAD
- 2nd gen 4runner lift size
- New guy
- electrical issue
- Is a 1992 regular cab long box rare?
- Nice runner
- Cruise Control Vacuum Weirdness
- wideband o2 questions.
- '90 4x4 Steering Pump Shaft
- I'm back with a new project
- clutch won't release
- 91 4x4 3vze Pickup started to bog and no power
- 4Runner console switches relocation
- Need help, truck won't start
- warm idle miss
- Front Differential oil seal replacement
- burning? smell
- Stuck in 2nd gear
- Ball joint spacers and 35s
- Replacing spindle bearing
- Fuel pump mounting bracket
- 22rte starting issue
- t case very noisy in 4hi
- 1992 Toyota 3.0 dead miss on 2 cylinders
- 91 Hilux Surf
- automatic 3.0 pickup stall issues
- Steering pump replace/system flush - 94 3.0L V6 4x4 pickup
- Coolant Disappearing
- Differential question
- 86 4runner ignition sticks
- Another 22re idle question
- Pulsating Steering Wheel
- Cold air intake
- tailgate relay box elimination
- I'm want to lift my 1994 Toyota Pickup. Good choice?
- Body lift rant!
- 92 xtra deluxe
- Need help making definitive id on the year of a 22r
- What is this?
- EFI fuse keeps blowing
- 88 Pickup Wiring Mess
- Starter sometimes clicks unless truck is rocked in gear
- 22R Replacing Cam, Not doing Head Gasket...
- 86 22r running hot/overheating
- What do these vacuum lines connect to?
- intermittent - rough idle/no start - Help 3.0 V6
- MkII supra irs in 1988 4x4
- 93 3.0 power steering pump
- map light bulb help!!
- Changing timing belt, water pump, power steering_'94 6cyl
- Cold weather issues!!!
- Gas milage
- can someone help me diagnose my truck?
- 4runner seat swap question
- 93 22re dieing
- Advice on buying a 2nd Gen (89) 4runner
- 12V Power Options
- need help going to burn it.
- let me see your Sas (;
- cup holder solved 84-88 pickup 84-89 4runner
- problem with thermostat and overheating
- Can someone help me identify this hose?
- 91 22re Toyota Pickup Rough Start/Idle, Hiccups/Sporadic....GREMLINS!!
- 4crawler TPS different than FSM??
- has anyone mounted a 40 inch light bar on the roof
- Odd droning, whining, humming sound
- E-LOCKER install question into 89 runner
- Engine and w56 ready to go in
- what's restricting my motor
- '86 4Runner Brakes Locking After Driving
- I Seek Guidance Please
- 22RE oil filter access?
- rebuilt 3vze crate engine with headers and code 52
- Bucket seats for 1990 22re 2wd pickup
- 4 Door 1st Gen 4runner??
- Weird Temperature Issue.
- anti lock or non anti lock?
- 22re not running questions
- Best windshield wipers?!
- Power steering help
- 86 Pickup Factory trailer wiring
- Check out these emission numbers!
- Time to replace Cold Start Injector? 89 3vze
- Charging issue
- What sequence should I be diagnosing alignment problem...
- Oil in intake runner #4
- 1986 interior help!!!
- 3rd member slop/play how much is normal
- Leaking oil!!
- 3000 -4000rpm idle problem
- Front mounted receiver hitch
- Wow 5k-6k for new 3.0
- '93 4Runner code 25 please help
- Oil inside my radiator
- can't find the right distributor cap??
- Need help, engine shake at idle
- blazeland 4x4
- 92 toyota 3zve plenum gasket
- Looking for a new radiator,
- '88 4runner Tranny Swap Hard Start
- 2nd gen suspension lift....yeah i know!!!
- '87 22R Federal Distributor vacuum advance routing?
- Loss of performance / cam getting wiped
- A340h w/ADD swapped to A340h witout ADD....no 4wd!! What am I missing??
- How to clean ventilation system on 84-88 trucks
- 3VZE smokes on start up and on acceleration
- Help: dying at idle, lean
- 3vze upper water outlet
- 1994 T-100 Vehicle speed sensor?
- What Aisin Clutch? '89 4wd 22r Pickup
- New Ticking Noise
- need help ruuush with oil gauge
- ac oil
- Regearing question
- 22re Idle Issue
- Nornal TPS reading yes or no?
- oil pressure gauge fix??
- 1994 V6 (VZ-E) engine bucking
- 99 trd tacoma locker
- Sun roof size
- Jumper!
- Installing clinometer and "long" dash pad into 89 4runner
- my truck has problems switching into 3rd gear!
- Ignition Switch or Starter Issue
- part identifie
- First 22re head gasket repair
- speedometer speed sensors what can be done
- 1987 truck with 167k
- Sticking starter
- How do I remove these bolts?
- Weird intermittent noise.
- 22re Rotella 15w40
- Which head gasket
- 88' 22re pickup oil leak question.....?
- Still Having Idle Trouble with my 22RE
- a/c idle up vsv compatibility
- 88' 22re clutch head scratcher......
- throttle won't close at idle
- Please help...should I buy this truck?
- Possibly blown headgasket
- Fill plug
- Best Aftermarket Radiators and Heater Cores?
- Kickdown/Bowden Cable Routing Question.
- Hesitation in 2nd and 3rd new engine
- HELP! New Head Gasket with a lot of smoke!
- 87 xtracab tranny issues
- how much lift do I need for 35s??
- 22r weber help needed......
- 22re don't stay running after head rebuild
- 92 grill replacement
- HELP. Post head gasket code 14
- Truck rides crooked
- Cam and rocker assemblies
- Stolen car recovery suggestion
- can't find rear motor mount!!!!
- Idles Rough, Oil Warning Light came on,
- 11k miles !
- Sleeve Yoke on Rear Drive Shaft
- Chunks of rubber in PS fluid
- rear wheel bearings
- winch bumper
- 88 pickup losing power
- Headers - Exhaust name brands
- Bad door locks 2nd gen runner
- Another issue with rear window
- what size of fuel line or brake line do I need for my 1988 truck
- **help!!**
- where to find window rubber channels
- Finally! She starts every time!!
- Looking for parts
- Looking into 22RE Engine rebuild... a few questions
- AFM code 31
- 1990 Pickup, parking brake loose
- Overheating issue
- 22re Idles weird, runs cold, cuts out....
- New Engine Surging Idle
- Fluids to use on change 94 4x4 4runner
- 95 22re rebuild machine shop socal location
- anyone running windshield light bars?
- my new 92, all about fuel mileage!
- My to-do list
- Manual to Auto Swap
- Throttle body
- 95 22re rebuild
- 86 steering column cover rattle
- dazed and confused
- New head gasket. Now truck won't start
- 89 4 runner auto trans troubles
- Transmission question.
- 2nd gen to first gen 4runner shifter bezel/trim
- 1990 4x4 clutch problem
- Schematics needed
- Broken torsion bar
- Clutch Pedal Support Assembly????
- Sway bars
- Puking trans oil out the shifter?
- easiest way for clutch replace ?????
- transfer case wiring question
- sputters and no power when ran for a little bit
- 1994 P-up speedo going in and out
- Brake booster question
- My 87 Toyota 4X4 or Fun and mysteries of restoring a Toyota 4X4 that is a "gem"
- Parts to replace while rebuilding a 3.0?
- 91 4runner 22RE questions
- oil sending unit
- How to replace the key cylinder if I can't get the key to turn to acc?
- 94 Toyota 4x4 no power
- 22re exhaust / cat delete
- Need Info on 22re motor
- Front brakes dragging
- If your Yota could talk...
- check engine light no pauses
- HELP injecters wont fire on my 86
- blind nut sheared off inside frame
- Catalytic Converter
- Best Radiator
- rebulding 22r problems
