How do I remove these bolts?
Old Feb 8, 2015 | 10:16 AM
Crazy_Guy97's Avatar
I have 94 Toyota 4x4 that I'm taking out the ignition switch .I came across two weird looking coned shaped bolts.How do I remove these bolts.
Old Feb 8, 2015 | 10:25 AM
millball's Avatar
You are probably talking about the ign switch security bolts.
The heads on these are broken off after assembly as an anti-theft measure.
When I encounter these, I use a Dremel with a cut-off wheel to grind a screwdriver slot into them, so that they can be removed.
I like to replace them with allen head bolts when things go back together.
Old Feb 8, 2015 | 11:14 AM
wyoming9's Avatar
Red face
About the best way!!
Old Feb 8, 2015 | 05:49 PM
scope103's Avatar
Toyota recommends a screw-extractor. http://personal.utulsa.edu/~nathan-b.../6tiltstee.pdf
If you have ever used a screw-extractor, you'll realize that millball has a better way to do it.
Old Feb 8, 2015 | 06:02 PM
bswarm's Avatar
I use a small hammer and chisel to back them out enough to loosen, then finger them out.
Blamalam
Mar 12, 2022 07:34 AM
Sep 4, 2015 09:27 AM
accuracy
Aug 6, 2015 12:32 PM
TJWilly
Jul 31, 2015 02:05 PM
Snort
Jul 9, 2015 03:58 PM
