Coolant Disappearing
Old Feb 20, 2015 | 12:09 PM
pinks315's Avatar
I have a 91 pickup with the V6 and 4wd. I live in Boise with pretty mild winters.
All winter long with temps below 35 the truck had blown HG symptoms (Losing coolant, white smoke out tail pipe) so i parked it and and bought a little focus to drive through winter. About 2 weeks ago i went and fired it up. No white smoke drove it to the grocery store it was surging and shaking while driving at low rpms. So i looked under the hood and saw the spark plug wires were from 1991. I decided to give her a tune up. Put some NGK V power plugs and cheapo duralast wires in there. Viola fixed the shakes. Plugs looked alright besides all being around .080 gap from wear and tear. One had part of the insulator blown off. After driving it about 30 miles all the coolant is still there. Wondering if anyone else had a similar issue
Old Feb 20, 2015 | 12:13 PM
pinks315's Avatar
Also the plugs from cylinders 5 & 6 had what looked like oil on the wire side of the insulator. I did change the oil it was dark dark brown and had a little amount of white goo on the oil cap.
Old Feb 21, 2015 | 10:10 AM
Cookie Monster's Avatar
Glad you got the rough idle/low rpm sorted out!
The old issue does sound like a failed HG to me, maybe after sitting for a while the gasket "reset"? If so I would imagine you will start to see the " disappearing coolant" issue again soon... Keep an eye on your oil for coolant, and keep an eye on your coolant for oil and hopefully everything just fixed itself :p
Old Feb 21, 2015 | 12:35 PM
pinks315's Avatar
I also used a block tester and results came back negative. Bluest fluid ever. Anyone want to buy a truck?
ladybugRC
458
Aug 21, 2020 10:41 AM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
dzldust
7
Oct 6, 2015 05:39 AM
puddlepirate
Sep 29, 2015 08:02 PM
