New Ticking Noise
Old Feb 10, 2015 | 04:18 PM
Gargoyle_Runner's Avatar
New Ticking Noise
My motor has @3000 miles on it so far. Just had the block machined and rebuilt with a master pack from Engbuilder along with a new head from Engbuilder as well. Recently I started getting a ticking noise that has gotten progessively worse. It is very noticeable when it starts cold in the morning and then quiets as it warms. Once at temp it's only heard when the motor is under load. It sounds like it's coming from the exhuast side of the one or two cylinder. I've pulled the cover and checked the gaps on the valves and made sure no to over tighten the cover. It really sounds like a valve tapping though. The head is new however and I can't imagine a valve would be sticking already. The ticking/tapping also just started in the last few weeks so it's not like I somehow smacked a valve into the piston during install because that would have been obvious from the get go. It worries me because it's getting worse. Any ideas?
Old Feb 11, 2015 | 04:43 AM
Badger62811's Avatar
Sounds like it may be a small exhaust leak. As the metal heats up it expands and nearly seals it off. I wouldn't rule out something else completely, but that's what it sounds like to me
Old Feb 11, 2015 | 06:35 AM
Odin's Avatar
You can get a cheap $4 Mechanics Stethoscope at Harbor Freight to help you locate/determine the source of the noise http://www.harborfreight.com/mechani...ope-69913.html
Old Feb 11, 2015 | 09:16 AM
grumpin's Avatar
I agree, had a Ford 460 that would do that, in the winter, not in the summer.
Old Feb 11, 2015 | 01:02 PM
I sent an email to Ted at Engbuilder and he suggested the same things. I put a stethoscope on it and the manifold had a pretty steady hum all over it. The valve cover didn't scream at me either. The nuts that hold the cover were the most pronounced as expected. The rear exhaust side was the loudest. I pulled the cover and went through valves again, engine warm everything was to spec. Buttoned everything up and the tapping continued. I even checked the dizzy and power steering pump since they seem to be in the neighborhood of the tapping. Not that I expected to hear anything from those but I figured why not. Just a steady hum also. Scratching head as we speak.
Old Feb 11, 2015 | 03:04 PM
grumpin's Avatar
Did you check if your exhaust manifold bolts are tight?
Old Feb 11, 2015 | 05:19 PM
I took the Runner to the machine shop that built my block and he was also thinking exhaust. Tomorrow I plan on pulling the manifold and giving it a once over. The machinists said to bring it by and he would check the edge on it. Ted from Engbuilder said these stock mani's were known for internal cracks. So I might be looking at a new manifold which is better than something in the long block. Did some reading on headers vs manifolds last night. I don't have a need for high end power gains. It seems like a reputable low end header is going to cost somewhere in the $500 range which is not in the budget right now. The stock manifold seems to be considered a decent option for low to mid range. Don't know what my best option for the stock manifold is though. The few on EBay didn't have a port for the O2 sensor. I've read mixed reviews on the Dorman product that pops up. Unfortunately the nearest bone yard to me has nothing 22RE related. Suggestions?
Old Feb 11, 2015 | 05:38 PM
skypilot's Avatar
Just wondering?? Could you look at the cam lobes for me. I wiped two cams and I'm pretty sure its because .gov mandated to remove zinc from the oil. So the cams in these 22re engines need zinc to protect the rocker / lifter and lubricate the cam. No zinc and the cams lobes at the top are rounded off, resulting valve tap for no reason (pass) because the top of the lobe is missing.
Currently I put in a bottle of STP to get the zinc back in the oil.
Old Feb 11, 2015 | 05:57 PM
I will pull the cover tomorrow morning when I'm yanking the manifold and snap some photos of the cam. The cam has about 3000 miles on it. I used zinc when I installed it. I've changed the oil a couple of times due to the rebuild break in but haven't used any additives. I've never seen a bad cam that I'm aware of and don't know what to look for. I will post some pics in the morning. Thanks
Old Feb 11, 2015 | 06:10 PM
Odin's Avatar
As far as additives go I honestly don't know how much stock I'd put into STP additive, or ANY additive for that matter. There are reports that state adding anything to an oils designed protection package can alter it in a way that will actually lower the protection. The same goes for mixing oil weights even if it's from the same line, from the same manufacturer. I don't know if there's any truth to it though.
ZDDP Plus is what Crower and Isky recommend these days. Both are old and very reputable cam companies. EVERY cam company used to recommend General Motors OES until they changed that for the government too. Well every cam company I know of except Competition Cams, which recommended their own break in lube. As I understood it the Comp Cams break in product was garbage back then.
Unless they've changed it Valvoline Racing VR1 still has a good ZDDP package that protects high wear areas like cam, rockers, and in other engines, lifters.
Old Feb 11, 2015 | 06:33 PM
Prior to my rebuild I just changed the oil. Occasionally I would use Lucus oil treatment but otherwise just castrol high mileage synthetic blend. That motor ran smooth and quiet for the 30,000 miles I put on it before it got super hot and demanded a rebuild. I decided to upgrade the cam while I had everything apart. I followed the break in procedure for a new cam but haven't done anything special for it since.
Old Feb 12, 2015 | 09:34 AM
grumpin's Avatar
Rockauto has Dorman and ATP, but I've never reseached either.
Old Feb 12, 2015 | 04:05 PM
Problem solved. Bad manifold. I pulled mine off and a visual inspection didn't raise any red flags. So I took it to the machine shop and they checked the edge and it was good. He gave it a good once over and still didn't raise flags. This was the same guy that thought it sounded like a leak somewhere around the manifold, so we were both confused. The gasket didn't show any signs of stress either. Nonetheless he called a buddy of his that had some 22re parts and found a manifold he would be willing to loan me to see if there was any change. What a difference it made. Not only did the ticking go away the motor is much smoother all around. Thanks everybody for giving me your thoughts.
Old Feb 12, 2015 | 04:06 PM
The guy that loaned me the manifold ended up selling it to me for $40.
Old Feb 12, 2015 | 04:49 PM
That's a win. Good work dude. Glad you figured it out
Old Feb 13, 2015 | 02:25 AM
grumpin's Avatar
Great! That worked out well.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
