- odd 22re problem
- Wreck with my '89
- Code 14
- Injector PRO (injector rebuild)
- Exhaust Manifold
- oh I love tax time!
- Noob looking to get into a 4 runner
- Auto Trans Problem
- Rear camshaft seal
- Trannie cooler -- what size fits?
- Tranny rebuild. Cost estimate??
- BJ Spacer questions? I Know I know...
- truck makes a weird ticking noise underneath
- new video of my V8 truck
- Automatic transmission rumbling noise
- fender flares
- Vibration!
- vet advice 1988 4runner
- need advice on the trail rig
- 1994 5-speed p/u
- Best Cam Choice
- How to jack the rear up...?
- plugging a tire
- Heater core installation problems
- Catalytic Converter Stolen today!!
- Rear window problems
- Remote Controlled Fog Light Set-up
- Warning Indicators Intermittently On
- More wonderful 3vze issues for everyone!
- 22re very bad idle possibly vacuum leak
- Gen 1s - Paint the top or not?
- coolant leak...a bad one i need info ASAP!
- Automatic Transmission?
- diff guard
- 92 with 3.0 6cyl EFI WHat engine?
- engine/transmission cooler
- new rebuild 22re some smoking
- WTB Lift Kit!!!
- fiberglass caps and fuel use?
- Exhaust manifold bypass.....something a little different maybe
- i've got a crazy idea.
- Building a turbo set up for my 3vz...help me out
- my project is almost done
- Gauges
- Rotor change out.... problem....
- Anyone rocking a tube bumper with 31's?
- Interior Question
- Electrical diagrams and problems...
- A340H in a first generation 4Runner???
- buying a new rear end
- I got bored
- I've got my work cut out for me...
- climbing idle (22RE)
- T3 Turbo Swap Questions
- WTH? Different tire sized
- sluggish, poor aceleration after rebuild
- Standard Tire sizes to Metric sizes HELP?
- tranny question
- Locking Center Console
- FSM question
- how do you do this?
- Brake question
- Power Steering Pulley Nut on 3VZ
- CVshaft quick change
- Rough ride with the top off
- factory air for OBA
- Oiling head bolts?
- Stripe or Not to Stripe?
- Rear defrost wiring hookup 88 4Runner
- Teeny Tiny Springs in rear diff.....
- Need Step by Step Guild (valve cover and seals)
- No time to open the doors
- '94 4Runner Restoration
- M/Ts, front locker, chains or what?
- Can anyone tell me how? Cluster question.
- Canopy/Topper question(s)
- Gearing for mileage?
- Cylinder head for '87 4x4 question
- Strange electrical problem
- I have a project for the weekend!
- A/T temp light?
- WOW! 1990 4-R 2 door with 50,000 original miles
- Clutch ?
- Lights?
- people in bc canada i have a red light camera question
- Someone who knows 22re's well. HELP!!
- Help! Sunroof stuck open!
- 22re motor leaking oil
- Tailgate window motor replacement options
- Winch Bumper Rack - Where to get one!
- Crazy shifting auto before and after TPS adj.
- brake conversion???
- Gears for a 1991 4Runner V6
- Sell the 4Runner?
- Now for the bonus round...
- hi-beam question
- Does my 22re sound like its knocking?
- 92 22re oil in water, water in oil, hot, leaking timing chain cover
- Rear wiper blade
- double cases????
- solved half the problem ..i think
- vibration rumbles whole truck low speeds please help
- 2wd frame to 4wd truck
- Drivetrain chattering/vibration...
- New Rear Speakers Installed!
- 95 steerling column in an 88? or steering wheel?
- Comfy seats
- Aftermarket CD Deck Instalitaion Problems
- 3vzfe running like crap after fresh valve job
- light wiring problem
- wrong intake manifold?
- Valve adjustment 3.0
- Tps problem????
- Newbie sayin hey
- how do u clear 33 12.50s with no after market lift
- 2nd gen. exhaust
- anyone with trail gear sas kit...which rear lift do you recomend??
- Leaf Springs
- 3.0 Head Gasket
- 22RE Replaced, No Start
- 3.0, black box by coolant resivor, what is it and do I need it?
- 93 pickup 5 Speed Trans shifting issue...
- No Power At All - Help
- Warn Rockcrawler Bumper Install
- Starter problem
- 92 pickup factory rear leafs
- Why me..
- Dome lightbulb for 1987 Toy Pickup?
- LC Pro Air Intake Kit
- Need input
- Can anyone identify this and tell me what it does?
- help, are the beds the same???
- Starting Problems
- What gear set is this
- anyone in idaho?
- Steering wheel alignment?
- Wabfab Front wheel bearing kits Quality?
- People with tint on there runners
- SR5 cluster truck=4runner= :) ?
- Help, alarm, keyless entry and remote start
- all I wanted was some lunch...
- 93 22re transmission sticking in 3rd
- Test injectors
- Advice on car problem
- a ? about changind spark plugs
- Special tool to pull rear wheel bearings - Houston
- HELP!!! Clutch or trans Problem????!!
- Installed 4X4 auto trans by myself
- Alarm system quality
- Where does this hose go?!?
- where is the IAC valve???
- Starter Staying Engaged.
- post some inside pictures
- 22re 5-speed top tranny bolt specs...length and thread pitch needed.
- Help!!!!! No brakes!!!!!!
- Harmonic Balancer maybe bad
- 22RE idle speed adjusting screw 85 4Runner
- Anyone with a Westin rear bumper?
- Converting to a SR5
- Yay cupholder
- rear gate glass malfunction, video
- seperating engine from bell housing
- steering box question
- Supra MAF
- Toyota fuel injection
- 90 4runner check engine problem.......plz help
- 22mpg last tank 12mpg this one
- A 3rd gen Toyota video... NO NOT THAT ONE!!! check it out, lol
- bought another one.
- Can you identify this wire?
- Clunking-Grinding noise only in reverse when wheels are turned sharp
- Why would my truck still be pulling?
- hi. new here. electrical gremlins...:( advise?
- hi guys im new here
- Water jacket on Throttle Body???
- Timing chain length?
- Steering coupling
- soldering up a Supra AFM
- my grille options
- valve cover removal ?
- New wheels
- Burning Steering Fluid on Startup?
- Pics of IFS Playing at Home
- IFS Steering Box Questions
- 92 dead spot at 65mph
- Rear Shock Replacement Tips
- Custom/Home made turn signals
- long start
- Finally! Toytec 2 inch lift before and after pics
- New front bumper!
- 22re cold starting problem
- If you need new rear leaf springs for your 1st generation
- Intro Just Got a 1987
- After shocks/alignment, you'd think I'd be happy...
- I need a steering stabilizer...suggestions pls
- SAS without gears/tires etc??
- 3.0 valve cover gaskets vs. gasket maker
- Help Weird Idle Problem Please read
- Need advise asap, please
- How do I check a 22re oil pump
- ECM mods 3vzfe?
- Air Flow Meter mods
- 4x4 calipers on 2wd ??
- interior colors
- Is this normal for an Automatic?
- can a plumbing coupler melt, just did an isr
- dangers of running GL5 in the tranny?
- 2nd gen cup holders?
- Timing Chain
- just did an isr today
- MPG diff. between tires
- Fun Stuff!!
- What do i need for offset?
- Leaky Oil Pan Gasket
- modded 22re fails emissions at idle
- sway bar kit???
- underbelly skid idea
- on the fence for which gears!!!
- 95 pickup 3.0 sr5 oil?
- still smoking on startup. still frustrated.
- 4wd -> fwd?
- 3.0 V-6 oil pressure
- A.D.D. 4x4 and Trans. Problems....Need Help
- White Smoke at Startup, but goes away???
- MAF adapter
- gear oil
- custom air filter MAF question
- vin number decoding
- passenger power window problems please help
- truck twitchy when in 4 wheel drive.
- Front locker and gearing questions
- IDLE acting all kinds of crazy whacked out!
- Strange Noise from DASH!?!?
- I noticed two things today...
- LC Coils
- engine diagram
- Gear Problems and leaks...
- Coolant hose confusion
- Real "notchy" 5 speed, is this Yota normal?
- HELP battery draining but everything is fine
- Clutch Failure, Slave Cylinder Failure, Air in Hydraulic Clutch
- r150 trans into a 92 v6
- 91 runner timing
- Any thread on cold start injection?
- Having a small ignition problem...
- Where to find some info
- Carb Rebuild
- home made "CBI" spare carrier
- Tellico with IFS?
