Vibration!
Old Feb 12, 2009 | 08:06 PM
toyotanick's Avatar
Vibration!
ummmmmm i think i might have a bit of a problem. i went climb some stuff and had a bit of hopping happen. ever since then i have a bad vibration when i first take off... anyone have n e idea? idk if it could be u joints but i sure as hell hope it is!!!
thanks for any help that you can give me!
Old Feb 13, 2009 | 05:31 AM
toyotanick's Avatar
noeone has any ideas?
Old Feb 13, 2009 | 07:57 AM
22mr2's Avatar
it does sound like a u joint or if you were really working the clutch, the disc may be glazed or warped. Id shake down the driveline first.
Old Feb 13, 2009 | 04:51 PM
toyotanick's Avatar
alright, thanks ill give that a shot and get back to you
Old Feb 14, 2009 | 08:26 AM
papadekaitlyn's Avatar
Check the transmission mount too while you're under there...
Old Feb 15, 2009 | 07:22 PM
toyotanick's Avatar
for a shake? allrighty
Old Feb 16, 2009 | 10:44 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I started getting "chatter" when pulling out of first and it appeared to be cause by my tranny bolts being loose/gone. The vibration was being cause by the engine and tranny seperating. Make sure you havent had some bolts trying to play David Copperfield on you.
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
tinigunner11
Aug 14, 2015 01:19 PM
