hi-beam question
Old Feb 9, 2009 | 09:12 PM
xzyragon's Avatar
hi-beam question
hey when u guys turn on ur high beams, does the passenger side light go to high-beam while the driver side go super dim?
mine does even after i switch the high / low beam wires around.
Is it a problem with a fuse or connector?
Old Feb 9, 2009 | 09:19 PM
Matt16's Avatar
No, its either both low beams, or both high beams. The two headlights are always the same as each other.
Old Feb 9, 2009 | 09:24 PM
xzyragon's Avatar
mmmkay, well it seems that on my lights
Normal
passenger: normal
driver: slightly dimmer
Highbeam
passenger: highbeam
driver: super dim (like an uber ultra lowbeam)
i switched the highbeam / lowbeam wires too on the driver side light and still the same
Old Feb 9, 2009 | 09:28 PM
toyota4x4907's Avatar
ever think to try and replace the drivers side light?
Old Feb 9, 2009 | 09:48 PM
xzyragon's Avatar
oops, forgot that
both bulbs are brand new and are exactly the same type from Pep Boys, sylvania bulbs or somethin.
Old Feb 9, 2009 | 09:56 PM
nv4runner's Avatar
Track down your drivers side headlight ground! Its either loose, dirty, corroded, or some variation of those. It wouldn't hurt to clean up your passenger side ground either.
Old Feb 9, 2009 | 10:01 PM
xzyragon's Avatar
@ nv4runner
sounds like a good idea, ill pursue it tommorrow after HW.
Old Feb 9, 2009 | 10:36 PM
abecedarian's Avatar
or maybe swap bulbs left to right and vice versa
Old Feb 9, 2009 | 10:39 PM
xzyragon's Avatar
problem still occurs when i use my extra bulb (the only living headlight from crash)
Old Feb 9, 2009 | 11:03 PM
desconhecido's Avatar
Could be the combo switch. Check out 4crawler's discussion of combo switch function and repair http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old Feb 10, 2009 | 07:41 PM
xzyragon's Avatar
pretty sure its not the switch, and its not the ground wire (unless i am missing it)
i dont really need to fix this to drive, its just an annoying nuance
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
