Air Flow Meter mods
Old Feb 6, 2009 | 07:13 AM
dem0nk1d's Avatar
Air Flow Meter mods
I remember reading some where there is a stock Air Flow Meter, that is actually bigger than the stock V6 3.0 one. Is this true and do you have to adjust it to get the correct air to fuel ration once installed. I’m looking to open the whole intake system correctly. This would start with a bigger Air Flow Meter, Bigger piping from the air flow meter to a bigger bore throttle body, and a ported and polished intake manifold. Then I would be looking into a possible header that has proven to work. I know with the whole intake and exhaust system the gain in power should be no more than 10hp. Max.
Old Feb 7, 2009 | 11:10 AM
space-junk's Avatar
search feature works great...
try using it to search for the camry AFM swap...
negligible difference, but its something else for the "cool factor"...
Old Feb 7, 2009 | 11:21 AM
abecedarian's Avatar
1st, calculate the total wide open air flow requirement of the engine at redline + 50% (for margin-error/safety considerations)
2nd, calculate the air flow capability of the intake system.
3rd, calculate the flow capability of both the throttle body and the air flow meter.
As is apparent, you'll have to do some measuring and such in order to reach your answer.
Old Feb 7, 2009 | 11:23 AM
Or on the other hand... I'm suggesting you are grasping at straws....
Old Feb 9, 2009 | 09:14 AM
dem0nk1d's Avatar
So another question why didn’t Toyota engineer the Air Flow Meter box round? I would think the square design with create a ton of turbulence.
Old Feb 9, 2009 | 09:41 AM
A round passage would make designing the flap/vane mechanism inside more difficult.
Old Feb 9, 2009 | 12:29 PM
Matt16's Avatar
Yep, round would be quite tricky to design. There isn't anything wrong with rectangular.
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
rjtrials
Aug 6, 2015 07:25 PM
bighaydn
Aug 4, 2015 07:17 PM
