- Couldn't Get Snap-ring on CVs....
- reverse light switch location
- New rearview mirror/map lights roof console ideas???
- Intermittent noise when manual hubs locked
- 90 4 cyl 5 speed bearing noises?
- clutch chatter!
- 7/8" vs. 15/16" wheel cylinders on my 89
- Lost power on 3VZE
- Engine Rattle? Video
- help bleeding a clutch
- Rough running
- What Air Filter do you have in your 2nd Gen?
- Seat swap into a EX cab Qs
- california vs federal emisions
- e-brake light getting annoying
- Fuel pump 1987 22RE
- New truck owner: 93 Xtra cab with some issues
- 88 4runner loss of engine power
- 3.0L 3VZE Oil Pressure too low?
- sdori ifs brace question
- how do i set the clock in an 87' xtra cab
- 22re wont start after cutting off amp wires..
- 91 4runner REAR LIFT QUESTION
- 86 4runner, terrible MPG and fells underpowered
- Parking brake cable
- OME rear leaf spring owners
- Knocking on 1986 22R
- Need Help Locating Cat Convert Bolts
- Temp Gauge Not Working 1986 22R
- Oil Leak 1986 22R
- Clutch Hose Replacement
- Did the 3.4 Tach Mod, how about a Coolant Sender Mod for pre 92 5VZ-FE swaps?
- 1/4 panels
- Manual Transmission Oil for 22RE
- Blown out Spark Plug
- 22RE failed oil pump??
- Starting Problems on 22R
- Transmission leak(Spraying)
- Codes 14 and 41
- Replacing fan bracket
- need help with 89 4runner!
- pulley problem on a 3vz-e
- TPS unplugged?
- Need Help- Hub Problem?
- LC Engineering Toyota 22RE Engine Rebuild - Wasabi Project's Sudden Acceleration
- should I buy used tranny, 350K miles
- 89 22r (206k) failed emissions
- Another *possible* timing chain thread
- 3VZE upper water outlet
- New to me 1987 Pickup
- O2 sensor keeps fouling and throwing a code 26
- Turbo
- no compression
- power window on passenger side dont work
- 1993 3.0L Engine Problems
- Ignition/headlamp buzzer location
- 1989 Toyota pickup Arm rest
- custom speaker door panel
- got my 33s and new pro comp wheels on!
- Need 3VZ Overheating Recommendation!
- Name this part! Heater/Coolant control something something.....
- Kaboom! (Wrecked my 4Runner)
- 91 4runner v6 falls on it's face when accelerating. help!
- 3.0 problem????????????
- a/c clutch throwing sparks.
- Coil diameter
- 1993 4Runner 3.0 5spd new to me
- Help converting a manual trans to automatic
- 22re new motor issues..
- Waterproofing Distributor
- Need Help Selecting Parts
- 22RE misfire that increases with RPM - Advice?
- Hitting brakes messes with idle
- 94 4runner 3.0 v6/5 speed 4runner extreme power loss
- 1987 22RE number 1 cylinder miss after motor swap
- 93 toyota pickup 22re surges at idles and dies
- 22rte smoking problem
- Need help finding wires for kill switches in 89 4runner
- ADD to Manual hub swap: issues after swap
- Rear Bearing removal trouble
- Electrical Gremlin 87 4runner SR5 5speed 22re
- digital gauge swap??
- Looking for ideas: Custom Door panels DIY
- I got spark and no fuel now : (
- My 1st gen 4runner Roof Rack
- Head Gasket, Timing Chain Cover, or what?
- 88-89 4runner sr5 Radio Tape player pics?
- PLEASE HELP with my 95 4Runner issue - see my video here...
- 22r wont start, just click
- 22re trans oil level
- Reran o2 sensor wire to comp, still coded
- auto trans wont shift
- More Power out of my 22RE?
- Fuel problems
- 94' 22re rough idle, beltching radiator and poor timing...
- how many of you guys are running IFS OME leafs
- Convert CA to Fed specs? 95 4runner
- 22re alternator fuse
- Spuddering Idle, fine after a while
- $12 ElCheapo Budget Boost Installed With Pics And Butt Sag Fixed!!!
- Preparing for a timing chain job
- 3vze problem...any ideas?
- 87 4Runner 22RE troubleshooting help needed
- 22re revving up while in gear
- 22RE Engine Harness
- 92 pickup (22re) Hesitation and jerky acceleration
- 22re rough idle in gear???
- 87' 22r 4x4 5sp brake Q's
- Finished 3.0 HG and now it won't start
- ! Tranny Re-install Tips !
- A/C Recharge 94 4runner
- 87 4x4 regular cab suspension is shot
- code 52 1990 4runner
- Tach Cluster swap, no coolant gauge now?
- 88 4runner coil arc issue
- TBA - Throttle body Differences
- knock in motor
- electrical to mechanical speedometer conversion
- No Power to ANYTHING Fix
- 1/2" tire size difference front/rear
- My 3.0L 1995 rebuild With pictures!
- Help! Purchased 2 days ago.. 3VZE leaking oil into Auto Trans??
- Coil retainers?
- Control Arm bushings- A misadventure
- AT Transfercase coolers, how much pressure are they under?
- ifs bushing questions
- 22r stock carb no fuel in sight glass
- 86 4runner rear window will not roll down - HELP Please
- 15-year old exhaust nuts...
- Oil leaking from catalytic converter?! *pics*
- 88 Toyota new to me
- Throttle Body/IAC Cleaning
- New rear shelf in my pickup.
- Put on the tube doors!!
- Cluster on 92 pickup?
- Knock sensor?
- Rear axle broke
- no more code 71 look !!!
- aftermarket transfer case coolers?
- almost time for a clutch
- Cant get truck into 4 wheel drive
- AAV and check engine light
- Differences in water pumps?
- 22re Timing
- Bad Solenoid(s) ?
- Ball joints & control arm bushings...
- Snorkel for 88 pickup
- 87 22re 1-wire or 4-wire O2?
- '89 3vze rattle tranny flex plate
- signals on my 93 yota dont work.
- 94 4Runner V6 - Runs Rough on WARM Start
- pickup interior pics
- water pump gasket leaking after replacement
- Bloer motor/ Fan switch
- possible blown motor - head gasket?
- Instrument cluster bulbs
- 3.0 Hesitation during acceleration
- 2nd broken brake line
- Seats for taller fellas
- Changing headlight housing?
- AT transfer case question, does it pressureize in 2H?
- Head gasket Hawaii
- 1986 4Runner 22RE rough idle, rich, no power
- '86 REC Rebuild Problems
- Baby moon hub caps?
- Fresh 22re rebuild. Got some questions.
- cleaning egr passages in the plenum?
- 3VZ stutters/stalls when attemping to get going and no idle... Big Problems
- 4runner rear window repair walkthrough
- Unanswered Bucket seat Q's
- Steering after SAS
- 3rd row seat using a bench seat from a Jeep YJ
- 11 in lifted toda with a dual t case question
- Gas Mileage after rebuild (3VZE)
- Dead yoter
- New to toyotas and need help
- 4 Crawler BL installed...(PIC LOADED)
- Valve Ticking
- Rod Bearing Replacement - 3VZE
- Painted the campershell
- Idle air controller?
- (ABS?) Braking Issue
- Panhard Drop Offset
- 22RE blown - how did it happen?
- oil pressure gauge not working properly
- egr ports intake plenum?
- front n/s 1/2 shaft
- Help with 3vze intake chamber connections
- on the fly roof mount light bar.
- Is this a Weber carb?
- Clutch Releases Rough
- leaking oil question.
- Reverse works but only with wheels off the ground
- Show me some flex pics of your ZUK mods
- Bed mat or liner that will not scratch paint?
- Am I missing a step? Cant get rear window to role back up?
- selling my rte engine
- About my 87' Pickup
- 86 4runner Code 7
- easy to replace front passenger window on a 93 pickup
- 1988 4Runner 4wd Rebuild or Replace (22re)
- my $100 3vze long block
- yet another back window problem
- Running rich and poor acceleration - running like crap
- First drive with the DT 3.0 headers installed, first impressions
- 94' 3.0L new engine problems/please help
- '93 Yota P/U, acceleration problem
- hg dont still wont fire
- Crazy Idle after turning off air
- no spark 1993 22re
- Fitting a Warn 8274 on a 2 gen 4runner
- 4wd Fenders
- 4.88 7.5 IFS Diff Swap
- 3vze distributor ground wire?
- High pitched whine coming from drive shaft
- 1990 22RE AFM to MAF Conversion specs
- 87 Carbed 22r Stumbling
- ngk gp platinums spark plugs and code 71
- 5 speed and efi conversion
- swapping a 95 4runner center console-
- V6 Rear Rebuild
- 1993 22re tps adjustment??
- TIMING 3.0 3vze probs still!
- Need The Best Yota Minds to Diagnose My 3VZE Problems
- DIRTY intake
- 22re ngk gp platinums spark plugs beware!
- Driveshaft decided to fall out on motorway this am
- Starting Woes
- transmission adapters? Toyota Engine-->GM transmission
- What is this? 3.0 VZE leaking-parts ID
- CRAIGSLIST is GREAT! traded 91 4runner for a 92 Truck
- Help!! Steering wheel locked & key wont work
- Shift Lever Retainer: Replacement Needed?
- Starter problem
- 8" interchangeability or rebuild?
- How to hack a MT harness to work with an AT?
- runs good when cold
- BEGINNER'S 22re Timing Chain Failure / replacement / head gasket replacement
- 4runner doors with wing window
- 22re New Motor.. Low compression
- 3VZE Throttle Boby Adjustment Question
- mystery oil leak
- code 71 egr temp sensor
- please help wierd engine problem
- help with the belt
- Quick Question: drive shaft and lift
- installing A/C unit
- Hood mat
- Idler Arm Already? Some Qs
- ignition or fuel issue? 89 hilux pickup
