'86 REC Rebuild Problems
Old Jun 2, 2010 | 08:28 AM
NHEngineer's Avatar
I rebuilt my '86 SR5 22REC pickup engine [lower end only] after 5 years under a hemlock tree [the truck, not me]. All new just about everything including ignition stuff. I set the "0" on the balancer and the mark on the cam journal to the shiny link on the chain, my buddy checked it and I checked it again when I adjusted the valves. I'm about ready to park it back under the hemlock. The engine has no nut at all until about 2500RPM and even then it's WAY under powered. Any ideas?
Old Jun 2, 2010 | 08:32 AM
PismoJoe's Avatar
Did you set the timing advance? It should be at 5 degrees BTDC. Get a timing light and check it out
Old Jun 2, 2010 | 08:54 AM
NHEngineer's Avatar
Yup. In the book the timing spec was 6° but I couldn't even get it out of the driveway without 4X low range. At 12° the ends of the plugs turned white. It's now at 8° so at least I can get it back up the driveway. Forgot to mentione, it seems as though the cold start circuit isn't functioning. Barely idles when cold and idles at 2000RPM when warmed up.
Old Jun 2, 2010 | 09:00 AM
snobdds's Avatar
There is no manual timing advance on the 22RE. It is all controled by the ECU. The only version with the manual Timing advance, which is controled by vaccume, is on the 22R, the carb model. As soon as you take out the jumper from the diagnosis box it automatacly goes to 12-14* BTDC because of the ECU.
I bet your dist. is 180* off. Take out your dist. and put the rotor at 12 o'clock. Then put in the dist again and the rotor should rotate back to 10 o'clock. Then set the timing again with your light and it should be good.
Old Jun 2, 2010 | 09:32 AM
NHEngineer's Avatar
Would it even run at 180° off? When I put the distributor in I set the balancer at 0° and checked that both valves on #1 were closed. I then rotated the rotor until it lined up with #1 plug wire. It started on the second crank but it was obvious that something wasn't right, right off. I set the advance at 6° then 12° and finally back to 8°.
Old Jun 2, 2010 | 09:33 AM
NHEngineer's Avatar
By the way, this is an '86 with OBD 1, not OBDII
Old Jun 2, 2010 | 09:49 AM
snobdds's Avatar
Yea, the rotor should be at 12 o'clock when you put in the dist., then it will rotate by itself back to 10 o'clock or #1 plug wire. If you set the rotor at #1 and then put it in it will not be in the correct spot. Also if you look at the FSM, it will tell you to put the crank at 5*BTDC and then put in the dist. Don't put the dist. in while the engine is at 0* BTDC, always at 5* BTDC for 22RE's.
Now for 22r's you put the dist. in at 0*BTDC. Many people confuse this and they wonder why they have no power in there truck.
Old Jun 2, 2010 | 10:17 AM
NHEngineer's Avatar
The rotor contact is quite wide. My timing light tells me I'm firing #1 at 8°. Timing on this engine is mechanical not by the ECM.
Old Jun 2, 2010 | 10:59 AM
snobdds's Avatar
At 8* you should be able to at least drive the truck. Try some fine tuning by rotating the dist.
To tell for sure if you have a ECU controlled dist., is there a green plug running from the coil to the dist then from the dist to the ECU? If there is then the ECU is controlling the dist. If there is a vaccume hose running off it then you have a 22R dist. on a 22re motor and they will not work with each other. That might be your problem.
Old Jun 2, 2010 | 11:13 AM
NHEngineer's Avatar
OK, there are the two green connectors you've described so it is ECM controlled. I was wrong.
At 12° advance it runs but still not much power and I was afraid I'd burn the side wires off the plugs. After only 15 miles, the plug tips were white.
Old Jun 2, 2010 | 11:46 AM
PismoJoe's Avatar
You have to set it at 5* BTDC, then it should advance on its own 10-14* BTDC, not 12 to 14. I like to check it with a timing light at idle, then again to make sure it has advanced properly.
And our spelling lesson of the day is vacuum.
Old Jun 2, 2010 | 12:06 PM
NHEngineer's Avatar
I guess you're saying to set the timing a 5° statically; i.e. with the engine off, right?
Old Jun 2, 2010 | 12:25 PM
snobdds's Avatar
So exactly what I said.
And as far as spelling goes, that's why I have a secretary. I don't worry about proper grammer on a forum, typing from a blackberry. Don't be that guy!! Furthermore you knew what I was talking about so ...
Old Jun 2, 2010 | 01:30 PM
snobdds's Avatar
10-14 that is a pretty big range, and where is exactly 10* at? I see 12 and 14*. To the op, it's 12-14* when not jumped in the diag. box. Here is a picture for reference
http://www.4x4wire.com/toyota/mainte...n/image011.jpg
Old Jun 2, 2010 | 02:17 PM
PismoJoe's Avatar
Haha I know I was agreeing with you and don't get to emotional about the spelling comment, I was answering NH about the range...
You're right again, that is a large range, if it is within that range you should be fine. There is no 10* mark, but if its between 8* and 12* then that's close enough.
And back to NH's ?, you set the crank to 5* while the engine is off
snobds had a good explination: "Yea, the rotor should be at 12 o'clock when you put in the dist., then it will rotate by itself back to 10 o'clock or #1 plug wire. If you set the rotor at #1 and then put it in it will not be in the correct spot. Also if you look at the FSM, it will tell you to put the crank at 5*BTDC and then put in the dist. Don't put the dist. in while the engine is at 0* BTDC, always at 5* BTDC for 22RE's."
Old Jun 4, 2010 | 01:43 PM
NHEngineer's Avatar
Please tell me how to set the timing with the engine off.
Old Jun 4, 2010 | 05:34 PM
PismoJoe's Avatar
You take a 19mm socket on a ratchet, put it on the crank, and manually turn the crank pulley to the 5* mark. (distributor is not on yet)
Make sure that you set it to true TDC before setting it to 5* BTDC. At TDC (the 0 mark on the oil pump lines up with the groove on the crank) the rocker arms of cylinder #1 should be loose. If they are not, turn the crank pulley a full rotation, then recheck, you should be at TDC then.
Now, manually turn the crank to 5* BTDC, then install the distributor. Read snobds explination, its what you need to know about installing the distributor at this point
Now, you install your timing light, short terminals T and E1 of the check connector, turn engine on, and check to see that @ idle (750 RPM manual trans, 800 RPM auto trans) it is at 5* BTDC.
If at idle your 22R-E is at 5* BTDC, thats good! Now, un-short the test connectors, and see that the ignition timing advances between 10 and 14*. This is that acceptable range that I mentioned earlier.
If you haven't done this before, I recommend downloading the FSM for your truck here: http://www.ncttora.com/fsm/index.html
Good luck and take your time you can do it
Old Jun 5, 2010 | 11:20 AM
NHEngineer's Avatar
Geekers! Why didn't my $30 Climers manual give me those instructions? Thanks PismoJoe. You're a good guy.
Old Jun 5, 2010 | 08:44 PM
PismoJoe's Avatar
Haha thanks, and no problem
icentropy
Sep 16, 2020 02:47 PM
coleypull15
Nov 3, 2015 07:41 AM
Yota.Jay
Jul 23, 2015 08:08 PM
raiderhawks00
Jul 8, 2015 06:23 PM
karbin
Jul 5, 2015 11:37 PM
