- Rocker noise
- Replacing and rebuilding
- 3.0 Head Work - how much machine work do I need
- dijlops build up.
- 86 4runner torque converter?
- How many headgaskets has your 3.0 had in its life
- 4Runner tailgate... no power
- LCA broke
- www.engnbldr.com website DISAPPEARED!
- help find this strange high pitch and clanking noise
- Auto tranny/case problem
- latch
- Rim Seized to Axle?
- Blue 2nd Gen on Banner with tire carrier
- Aisin hub question - already searched.
- topless mud wrestler
- If you could upgrade 3 things...and an engine burble
- Fabtech Ivan Dan LT suspension kit
- Leavy Valve Cover project
- AIR COMMING FROM VENTS... Help!
- 1986 22r with heating issues...
- Venting Frustration: The 3.0 Knock
- replacement engines
- HELP!: 22R with engine/fuel loss when shifting...
- How Much Gear Oil
- what caused the headgasket for the 3vz-e
- do you trust your old 4runner?
- need recomendation
- Half doors!
- aussie locker
- '92 V6 hard to start when hot, lacking power?
- Glasspack, exactly how load are they??
- Winch mount for Warn 8000 on 93 pick up
- Looking for bolts
- Question about the rules here
- Vacuum and fuel lines to intake plenum
- My A/C is destined not to work
- Rear Coils Pro Comp vs. Moog vs. OME
- the best of both worlds..............
- What do i don? Valve covers leak???
- Making some progress on 81
- truck runs great.But
- New o2 sensor problems
- 3vze help! this is rediculous...
- Aisin o-ring
- 89 p/u cluth Adjustment
- Need help fast on my 3.0
- 22re machine work
- Single rear Drive shaft supplier??
- No brake lights! (kinda long)
- transmission and transfer case question
- Metal shavings!!!
- crank wont turn
- Corner/Parking Lights for sale . . .
- AC Relay need to be jumped on a 93 Pickup?
- what is this?
- Any Recommendations for ling road trip??
- 1988 toyota truck 3.0 4x4 not starting
- rear shackle question
- rear main seal
- Lift?
- rear shocks
- drop oil pan
- 86 22RE 4Runner
- 81 pu info tag
- 3.0 hard to start
- Rear drum to disc conversion info needed for 1990 4x4 truck
- 3VZE O2 sensor?
- timing advance problem
- Hilux
- eBay Parts
- engine problems!
- Code 25 questions
- the bucket seat thread
- What is the 3VZE Connecting rod bolt torque spec
- Those with a 2 piece rear driveshaft
- Mice in blower /Cowl area
- wires/fuel injection
- Wanted: 86 22re
- Inclinometers
- Gen1 4Runner Window Sticker
- Rust repair panels??
- '94 2wd Electric conversion, transmission advice
- Safe shackle length? 8" too long?
- trailrunner vs. prerunner
- What are my options?
- How to make a 3.slow even slower
- Anyone remember this 4Runner on ebay?
- Backup radiator fan on 3.0!
- Modified Hardtop
- 5M-GE supra engine swap into an 86 pickup?
- Single piece drive shaft
- My 88' 4runner timeline/build **pics***
- 3.0 Timing Question
- Tell me what you think??
- Auto Tranny and transfer case ?
- Gen1 4Runner Roll Bar - whats the "plate" for?
- Difference between 1988 vs. 1989 4runner leaf springs?
- Shackle lift quick question
- VW TDI in 1st gen runner
- tube bumpers
- Im not getting very good MPG
- Bolts, bolts.....nuts
- Time for a new 3.slow......Recommendations?
- Source:Rear bumper brackets??
- Trac-lock questions
- Bumper Rust out - Fix
- Damn it's 3.slo!
- 22RE fuel/electrical problems after Jaspers.
- batt symbol, odd idle
- Coolant leaks and oil leaks on a 91 4runner
- Pickup Replacement Parts Gen 6
- work in progress
- help! melted wires!
- Good Deal on ePrey
- 4runner custom sliders and bumpers planning
- Sputtering at idle and smog
- running boards
- my grown man tires
- check engine code 11 equals no spark...
- Belt Question - Please Help!
- Buying a reman 22 RE
- transmission problems
- 95 3.0 stumbling on first cold start in the mornings.
- Ignition Module Question???
- Difference between V6 and 4 Cylinder brake calipers ???
- Fuel canister line?
- Plastic Shavings on top of engine????
- Help!!! Installing rear leaf springs on an 86 2wd
- General Causes of Backfiring?
- Zuk's Coil Over Leaf Thingy
- Truck won't turn over at all no noises nothing
- fuel injecters
- leaky clutch line?
- trouble with headlights
- How hard is it to replace the injectors
- 94 Toyota Running Rich/Lean? Help!
- Leaking Coolant a HG or Worse?? *Pics*
- Auto tranny support
- 22re engine problems help!!!!
- Rebuild Transmission or buy used
- Throttle response,carb adjustment?
- Random check engine light
- Lift a yota?
- Timing help needed, 3.0
- timing
- Would this engine fit????
- Rad-Replace or Repair
- StealerShip = MORE Problems + some ranting
- 22RTE to 22RE....how hard?
- Ball Joints
- Radiator
- Brake pedal feel...Q for the Brain Trust
- Cv boot, grease & smell...
- Replacement Oil Filler Cap
- Rear Window Does Not Work
- does anyone have this?
- Mass air flow sensor.
- bed less
- 33X10.50 on an 86 4runner
- timing belt issues
- Running board removal pics before/after
- spark plug gap
- Changing brake pads on an 88 4Runner
- Just installed my add-a-leafs. 2" yeah!
- Weird shifting poss TPS?
- Pcv Q
- torque converter picture
- 3VZE running out of round
- Door LOCKS keep going up and down
- 102'' Military Style Anetnna & Tie Down.
- 93 taillight lenses
- Thinking about new tires.
- 3.slow will not start
- General Performance Question
- Starter Click
- Stock T-Bars Vs. Downey 26MM. need help with flex.
- Code 12 After HG Job
- Any good toyoter based bumper stickers?
- Some pointers on installing BJ Spacers?
- Newb question but....
- rough running 3.0 v6 210,700 miles
- Finding a Solid front axle
- HG issue with my 3.0 or possibly something else?
- Masking tape removal
- Bigger gas tank ? ? ? ? ? ?
- 22re bad oil milage
- ABS block off plate?
- Basket case 4runner ? about torque converter
- 94 4runner Rear Coils Pro Comp
- Removing Window Handle - 1st Gen?
- Transfer Case Stuck in 4HI
- twin T-case 86 with an 83 T- case?
- flywheel shaking????
- Winch & Brush Guard
- More travel?
- 1988 Toyota truck 3.0 fuel pump relay location
- Camberg or Total Chaos arms
- fricken dome light
- another 3vze HG repair
- Looking for pics-Lime Green Runner with chopped roof
- Adding Keyless Entry to 90 4-Runner
- BIG PROBLUMS vibration/grinding
- Loose Tailgate Hinge
- my cv has gone bad has anyone bought one from autozone
- Looking at doing 4.88's
- ac and heater blower fan?
- My steering wheel is shaking like crazy
- The start of a new project ( 86 pickup)
- Will '95 roof rack fit on '94 4runner?
- intake coolant passage
- Check engine lamp always flashing!?
- Downey fiberglass fenders
- Is it my regulator?
- 1991 4Runner body swap or engine/tranny swap?
- LSD in 94 p/u - an easy install?
- Bikini Kit installed - 88 4Runner
- bilstein 5150 series
- elocker wiring help???
- regear?
- ch-ch-ch-ch-check it out!!! *PICS*
- yota+jeep= wth?
- Need Wiring Harness
- F/R locked runners...any issues?
- Runnin Hot(er) than normal.
- Chevy Axels and Such
- Replacing rear window motor
- Tail light issues
- Locker or axle swap?
- A Quality Engine Block Heater
- Rear Window Shattered!
- 22r & 22re
- Tc Long Travel Kit
- Pics of the new Runner...
- Throttle response
- 4:88's in
- clutch solutions?
- Holy fuel leak!
- 1st Gen 4runner Advise
- A340 question - swap related
- 4wd not engaging....
- Problem Starting
- Easiest Way To Access Back Of The Block?
- A340H Torque Converter - Lock>Unlock>Lock>Unlock
- so what is the best way...
- 1988 toyota fuel pump problem
- another ac ?, advice needed
- New work truck/DD 88 Longbed Build (56K beware)
- custom intake
- Please Help, New Engine Install Oil Pouring Out
