86 22RE 4Runner
Old May 22, 2007 | 09:30 AM
weaselman's Avatar
86 22RE 4Runner
so i went to get it smogged and it wont pass because the timing is at 26 and it should be at 5
and also the HC was at 131 and that is the max for CA but it still passed all emmissions part...
any suggestions i should do other than time it correctly?
Old May 22, 2007 | 11:36 AM
Jay351's Avatar
Seafoam it? then run premium gas
Old May 22, 2007 | 06:05 PM
fullmann's Avatar
i've had vehicles fail, then I change the oil and it passed. its a fairly easy fix sometimes.
Old May 22, 2007 | 06:25 PM
4runnerx3's Avatar
I'm glad in NC they don't test them that old.
Old May 22, 2007 | 10:01 PM
Spanky's Avatar
86 is too old to test in your neck of the woods?? haha cool , its '72 here in utah... or last i heard.
Old May 23, 2007 | 04:45 AM
gametom's Avatar
that's the best thing about Illinois they only test OBDll Auto any more so 1997 and newer i think maybe 1998
Old May 25, 2007 | 06:23 PM
84sr5yoty's Avatar
and also the HC was at 131 and that is the max for CA but it still passed all emmissions part...any suggestions i should do other than time it correctly?
Well, if you correctly reset the timing, the rest of the exhaust emissions will probably come right into spec.
Before you attempt to adjust the timing, test the TPS for proper adjustment and function. It will be impossible to correctly set the timing with a bad or incorrectly adjusted TPS.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old May 26, 2007 | 09:15 PM
weaselman's Avatar
well i timed it to 5 degrees and it ran like ☺☺☺☺☺ and it would barely hold 55 so i said screw it and took it to the smog shop and it passed with flying colors, so i just put it back to 12 degrees so it runs and can actually do 80...so idk...could something be screwed up with my truck??
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
