drop oil pan
Old May 22, 2007 | 09:53 AM
tshezz's Avatar
drop oil pan
im trying to replace the oil pan gasket, as i was pulling it out while replacing my alt. im having a hell of a time getting this steering linkage apart. where should i disconnect it? i got a puller, but i feel like an idiot just tearing my bushings all to hell.
Old May 22, 2007 | 09:57 AM
ewong's Avatar
What motor?
In the 22RE with IFS, the pan will hang up on the pickup.
To get mine out I removed the front axle...
If all you are doing is replacing the gasket - its FIPG so you dont have to remove it all the way..
Old May 22, 2007 | 10:35 AM
TNRabbit's Avatar
if it's the 3.0 you need to unbolt the motor mounts & jack it up or drop your diff to get the oil pan off.
Old May 22, 2007 | 11:03 AM
tshezz's Avatar
its the 22r. how hard is it to remove this bar. geez
Old May 22, 2007 | 11:22 AM
ewong's Avatar
pan hangs up on the oil pickup. I think its possible to reach in and unbolt the pickup....
Old May 22, 2007 | 11:32 AM
SpeedyJ's Avatar
ewong is right. I replaced mine on my old 1986 22re and it took forever. Had to drop the front diff and jack up the frame. Also had to unbolt the steering stablizer and then unbolt the oil pick up thats inside of the pan. You first have to pull the pan as much as it will go then reach inside there and unbolt the pick up. Make sure you clean allll surfaces before putting the new gasket and RTV sealer on.
Old May 22, 2007 | 11:37 AM
8yota9's Avatar
i did my 3.0 in 30 min pickle fork the 2 tie rod ends and it comes right down.the oil pan was like 30 botls sum studs the rest bolts i have a 4in lift so i cleared the diff.i got 2 cork gaskets from nappa one for the pan one for the flange thing . if u dont have a lift beter get sum beers and a friend haha.
Old May 22, 2007 | 02:42 PM
toyota_mdt_tech's Avatar
Just unbolt the idler arm from the frame, and it wil drop enough. And unbolt the steering dampner.
Old May 22, 2007 | 08:06 PM
CyMoN's Avatar
on the 22r I worked on I removed the steering damper and unbolted the motor mounts and jacked up the motor by the tranny and then undid the oil pump line still was a hassle but I got it out and back in.
Old May 22, 2007 | 08:11 PM
May work, but way more than is needed. I have found the easiest way to do it. (see my above reply)
Old May 23, 2007 | 10:07 PM
trythis's Avatar
if you unbolt the differential, be prepared with help, or some sort of jack to get it back in place. Suckers are heavy.
Old May 24, 2007 | 11:10 AM
tshezz's Avatar
thanks guys
Old Jun 16, 2007 | 09:15 AM
termiflyer's Avatar
toyota_mdt_tech: Does this work on the 4x4? It looks like the front driveshaft/diff is in the way to get the oil pan off, especially with the oil pickup. It'de be great if it works, i just want to be sure i can do it before ripping it apart!
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
toofly1999
Jul 25, 2015 07:09 PM
Jnkml
Jul 6, 2015 01:20 PM
