Replacing rear window motor
Old May 14, 2007 | 09:16 AM
linuxrunner's Avatar
My rear window motor is dead and I thought I remembered a thread about using side window motors from other Toyota vehicles that would bolt in. But when I searched I could find very little info on this. Does anybody know if this is true and the make and motel I should be looking for?
Old May 14, 2007 | 09:22 AM
rentedmule's Avatar
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
all the info you need should be in there somewhere
Old May 14, 2007 | 11:14 AM
I have used his write ups alot for all of the other rear window projects i have done, but he has nothing about any new motor possiblilties.
Old May 15, 2007 | 04:12 PM
leebee's Avatar
corrolla rear door motors should work, i did that on my old 86 when the rear window motor went south on me.
lee
Old May 15, 2007 | 06:55 PM
rentedmule's Avatar
sorry, could have sworn there was info about what motors would work in there. when i had issues with mine i went through ~ 1 million threads in here and do remember reading that a rear door window motor will work but I think it had to be a specific side (ie passenger/driver) - something about the orientation of the motor being correct?
Old May 15, 2007 | 09:02 PM
toyzrus808's Avatar
my truck is a 95 runner and i used the drivers side front window motor for the rear.. almost the same the only diffrence was were the wires are but not a big problem..
Old May 15, 2007 | 09:29 PM
DeathCougar's Avatar
Both/Either drivers side window motor will work for the 4Runner rear gate. (Or only the left front if you have a 2door heh)
Pass side will not work, as they are clocked 180' off.
voiddweller
19
May 2, 2016 09:10 PM
scottt80
Jul 1, 2015 12:13 PM
markshoreline
Jul 20, 2002 01:00 PM
Corey
Jun 19, 2002 11:06 AM
