Random check engine light
Old May 18, 2007 | 02:36 PM
Alex 400's Avatar
O"k i ahve a little prediciment. I have been driving my truck around and it has been running great, no problems. Then I will be driving it and all of the sudden the engine check light comes on. no difference in how it runs or anything. So I get home and reset it and it goes away for about two, three weeks and now its back. Has this happened to anyone else?
Old May 18, 2007 | 02:54 PM
slosurfer's Avatar
try searching for how to pull a code, that way when it comes on again you can pull the code and see what is going on. Could be your O2 sensor.
Old May 18, 2007 | 03:17 PM
tampabayota's Avatar
they put the light there for a reason,pull the codes fix the problem then it will go away
Old May 19, 2007 | 06:27 AM
ovrrdrive's Avatar
Mine is doing that for an egr temp sensor...
It runs the same and goes off intermittently so I'm not worried too much about it.
When it's on pull the code and then you'll know.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
