flywheel shaking????
Old May 15, 2007 | 09:11 PM
toyzrus808's Avatar
if anyone has had this problem before please let me know... i changed my clutch in my 95 4runner 3.0 new plate, disc ,pilot and throwout. had the flywheel cut... put everything back shifts fine but when it's not in gear feels like the flywheel is shaking.. you can feel a weird shaking in the truck and as you raise the rpm you can feel it untill it gets to about 3000 rpm... wondering if my flywheel should have been replaced instead of cutting it... anyone have this problem before? and all bolts to spec.
Old May 15, 2007 | 11:32 PM
TNRabbit's Avatar
Perhaps they didn't get it exactly right? I've had rotors turned before and ended up with a pulsing because they didn't have it exactly centered when they cut them...
Old May 16, 2007 | 03:16 AM
toyzrus808's Avatar
yeah...gonna buy a new flywheel and change it... thanks
Old May 16, 2007 | 03:36 AM
RustBucket's Avatar
Are the flywheel bolts torqued down to spec? (aka, really really tight?)
Old May 16, 2007 | 05:52 AM
Flash319's Avatar
I have had a similar problem before. I damaged my pilot bearing putting the trans in. If you used the trans bolts to pull the trans to the engine you may have done the same thing.
Old May 16, 2007 | 05:53 AM
TNRabbit's Avatar
FSM says 65 lb/ft on 3VZE and 80 lb/ft on the 22re
Old May 16, 2007 | 07:08 PM
toyzrus808's Avatar
yep 65 lb/ft on flywheel bolts... i will check the pilot bearing when we rip it apart again. gonna get a new flywheel just in case. got some runout spec from toyota to check. thanks for the response everyone!!!
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
calderp
Nov 16, 2015 02:49 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
