Transfer Case Stuck in 4HI
Old May 16, 2007 | 05:40 AM
eaweld's Avatar
Anyone had the trouble with their transfer case being stuck in 4HI on a 1994 4Runner, 3.0 V6 with Auto Trans??? Correction, messed up 4L
Old May 16, 2007 | 05:52 AM
4banginRunner's Avatar
is there dirt/forigen object in the plastic track in wich the shift lever follows? or possably cracked or broken. it may be "locking" the lever because the plastic cover is jammed up..
if not, go on a dirt road and try to shift it out while rolling a bit, may be the tourque load on the drivetrain holding it there
Old May 16, 2007 | 05:59 AM
eaweld's Avatar
Transfer case issue
Had just installed a used JDM motor, transmission & transfer case into my 1994 4runner & first thing I noticed is 4wd light on, & stuck in 4Hi, even though lever is in 2HI... Its definetly engaged as you jack up the rear & it will pull itself off the jack...
Old May 16, 2007 | 06:14 AM
eaweld's Avatar
Meant its stuck in 4L
Old May 16, 2007 | 06:33 AM
DeathCougar's Avatar
yet another reason to never buy those Jap crate parts....
You may have put the shifter in wrong. Double check your transfer case lever, and make sure its in the correct slot.
Old May 16, 2007 | 10:40 AM
check linkage?
Old May 16, 2007 | 10:48 AM
mt_goat's Avatar
Yeah post up a pic of your transfer case shifting linkage (under the truck). Its pretty easy to get that bound up (especially if you have a bodylift).
Old May 16, 2007 | 11:26 AM
amusement's Avatar
My 1995 Hilux 4x4 had the problem of not coming out of four wheel drive.
I would go into reverse to clear it. In one instance I traveled over 60 feet before the transfer case disengaged.
Old May 16, 2007 | 01:32 PM
tc's Avatar
tc
Molly's won't stay in 4Low - maybe we need to get the trucks together and they'll balance each other out!
Old May 19, 2007 | 06:57 AM
thook's Avatar
Hey!!! Mine won't stay in 4L, either. (Ooops! Did I just tip the scale?)
Old May 19, 2007 | 07:25 PM
89red4x4yota's Avatar
try going under the truck with the truck in nuetral and the tires blocked so it doesn't roll anywhere and try playing with the linkage that way. might work
Old Aug 23, 2007 | 06:54 AM
4runnerguy's Avatar
1991 4runner v6 5 speed: i have a problem when put my truck in 4x4 hi or low all my tires one at a time they stop moving for a sec and starts again then goes to another and does the same then hole truck jercks around its like when a person does not know how to drive stick
Old May 26, 2009 | 05:35 PM
Skilo47's Avatar
Unhappy mine is stuck to =(
mine is stuck just like 4runnerguys.
i have the 91 pickup with manual hubs.
the 4wd light wont go off and when i unlock the hubs and put the 4wd lever in neutral and try to drive forward nothing happens it's like everything is disengaged .
4wd works fine though . anyone know what to do ?
Old May 26, 2009 | 06:40 PM
yoterr's Avatar
lol mine does it too, kind of a trend eh? but it just gets stuck in 4Hi and wont go into 2Hi, till i drive around a bit...
Old May 26, 2009 | 07:00 PM
Stuwy123's Avatar
Check for a leak to your ADD. If the valve is stuck one way, switch the lines, see if it changes anything. If not, the valve is stuck in one spot. This will get you out of 4wd at least.
Old May 31, 2009 | 06:12 AM
thook's Avatar
If you put the 4wd in neutral, of course you're not going to go anywhere. It's in neutral.
Old May 31, 2009 | 06:18 AM
thook's Avatar
Vehicles equipped with manual hubs aren't going to have ADD systems. Unless, someone has swapped out the hubs. Even then, you're out of 4wd once the transfer case is set to 2wd drive. Just the axle is still locked in together with the drivetrain.
Old May 31, 2009 | 11:21 AM
Skilo47's Avatar
now i know and knowing is half the battle. =)
i got it figured out though. all i needed to do was just back up a bit and push in the clutch and while the truck was still moving i pull back on the 4x4 lever and it popped right outo of 4wd.
Old Oct 10, 2015 | 04:13 PM
Rosscoe Massie's Avatar
hey i have a 91 toyota pickup stuck in 4hi but shifter is in what i feel is neutral, would doing this reverse drive also possibly help me?
Kreedy1
Sep 8, 2015 06:33 PM
eggens
Sep 5, 2015 12:16 AM
Tykiller1994
Aug 10, 2015 07:49 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
