How Much Gear Oil
Old May 24, 2007 | 02:23 AM
craw4x4's Avatar
How Much Gear Oil
DOES ANYONE KNOW ROUGHLY HOW MUCH GEAR OIL THE FRONT AND REAR DIFFERENTIALS TAKE , AND WHAT TYPE?? ON A 95 4RUNNER
Old May 24, 2007 | 02:41 AM
Elton's Avatar
should be pretty close to mine rear takes about 3qts front diff is a little over 1qt use ether red line or mobil 1 75w-90
Old May 24, 2007 | 03:21 AM
thook's Avatar
Here it is:http://personal.utulsa.edu/~nathan-b...21lubrican.pdf
REDLINE...if you can swing it.
Old May 24, 2007 | 03:27 AM
pat161's Avatar
I have a 3rd gen but I believe they use similar if not the same diffs. The rear takes 2.2 quarts and the front is around 1 quart. Just buy 4 quarts and fill them until fluid starts running back out the fill plug, this method works every time.
Old May 24, 2007 | 04:04 AM
Marc's Avatar
Remove the fill plug first just in case you find out you can't remove it after you've allready drained it.
Old May 24, 2007 | 09:39 AM
burtonsoldier's Avatar
fill it till its starts comin out
Old May 24, 2007 | 09:58 AM
91TPU's Avatar
my pickup was a lil over two for the rear, and i cant remember what the front was, i think i bought 5quarts all together to do the whole job, and came out with some extra
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
