Need help fast on my 3.0
Old May 23, 2007 | 07:44 AM
4rnr's Avatar
My 88 3.0 5spd 4runner, is having major power issues. Once I drive the truck around for a couple minutes I loose all torque. The truck can barely get out of its own way, UNLESS I push the excelerator to the floor then I can feel the truck instantly jump back to power and it pulls the way it used to. Also as Im accelerating under the light power the truck feels like it is chugging a but. I have replaced the coil, wires, cap, rotor, fuel filter, plugs.
Why do I have to have my foot to the floor for the truck to wake up?
Im leaving for a 700mi round trip on friday.
Old May 23, 2007 | 08:04 AM
TNRabbit's Avatar
Sounds a lot like a bad or misadjusted TPS. Check that it's plugged in and there are no bad wiring issues.
Old May 23, 2007 | 08:19 AM
95RunnerSR5's Avatar
any trouble codes?
Old May 23, 2007 | 08:21 AM
4rnr's Avatar
i dont have diagnostics reader, unless there is some other way to tell.
off to check the tps
Old May 23, 2007 | 08:29 AM
if the check engine light is on you can check the codes yourself.
http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
TNRabbit's Avatar
There is a way to check the codes..all you need is a paper clip!: http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Also here is info on the TPS: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old May 23, 2007 | 08:30 AM
TNRabbit's Avatar
Double post! High five, 95RunnerSR5!
Old May 23, 2007 | 08:43 AM
Funk_Runner's Avatar
*subscribes
Old May 23, 2007 | 09:36 AM
Old May 23, 2007 | 09:43 AM
yotasavg's Avatar
hmm this sounds like mine. but his is all the time....interesting.
https://www.yotatech.com/forums/f116/3vze-help-rediculous-116419/
Old May 23, 2007 | 09:44 AM
4rnr's Avatar
Wow, I got 6 codes
14
25
26
41
43
51
25/26 should be because my o2 sensor ripped out of my exhaust and is now dangling beneath the truck
Some of those codes are indicating TPS, some are indicating a starter issue???
By looking at those codes what do you think. Im going to go pick up a feeler guage and do the TPS adjustment. Since I didnt have a feeler I did check the wide open position resistance and it was 4.9Kohms which is good (between 3.3 and 10) But I guess I should check the others.
Old May 23, 2007 | 10:04 AM
hmm..i have no idea..igniter maybe? expensive tho
Old May 23, 2007 | 10:16 AM
tc's Avatar
tc
Old May 23, 2007 | 10:17 AM
tc's Avatar
tc
Seriously though - mine has done something like that, but not quite as bad. Seafoam helps, but I think changing the O2 sensor was the real fix.
Note: I didn't really record before/after data, but I seem to be getting quite a bit better mileage since changing the O2 sensor too. With the price of gas lately, it won't take long to earn back the money for the sensor (about $80 IIRC)
Old May 23, 2007 | 10:24 AM
snap-on's Avatar
id pull the codes, pull the ECU fuse (reset the puter, ie clear the codes) drive around and see what you get
TPS and/or timming would a place to start
Old May 23, 2007 | 10:28 AM
GM TURBO's Avatar
I guess I'd stick the O2 where it belongs.
Old May 23, 2007 | 10:33 AM
gonzo's Avatar
X2.
If that o2 sensor is just hanging there that will throw all kinds of s**t off. Fix that, clear your codes and drive it see if you get any codes back
Old May 23, 2007 | 10:49 AM
4rnr's Avatar
Well I checked the 4 points on the TPS and the 1st and 4th positions are within spec. The 2nd and 3rd positions are only readind about 12 ohms it should be 2300 ohms and infinite ohms. So that smells like a short.
As for the o2 sensor. I need a new bung or just that section of pipe with a bung in it and weld it all up then buy a new o2 sensor, and SPLICE it in. Does everyone else not have a connector for the o2 sensor or is it just me or am i retarded
Old May 23, 2007 | 10:52 AM
yotasavg's Avatar
ok. i'm trying to check my tps right now too....i think i'm retarded cause for the life of me, i can't get the damp needles on the prongs to check it.
how'd you just do it? and is the E2 on the top or bottom?
Old May 23, 2007 | 11:08 AM
4rnr's Avatar
e2 is on the bottom
