3vze help! this is rediculous...
Old May 23, 2007 | 09:40 AM
yotasavg's Avatar
so what's been happening has begun after i did the ISR mod.
during the day, at normal operating temp, the engine starts up fine and continues to run just as it should. 850rpm at idle.
at night however, when i start the truck it goes to about 250-300rpm and then dies if i don't rev the engine for a good two minutes before driving!?!
WTF? does my truck not like night time any more??? i seriously am stumped and through my extensive searching i have found nothing like this.....has anyone else had this problem??
please, any help is very appreciated. thank you in advance. i really don't want to have to take this to the stealer.....
Old May 23, 2007 | 09:44 AM
yotasavg's Avatar
forgot to say that i have checked the paperclip trick and it's throwing no codes.
Old May 23, 2007 | 10:17 AM
mt_goat's Avatar
Is it normal if you turn off the headlights? Sounds like maybe an alternator problem.
Old May 23, 2007 | 10:18 AM
snap-on's Avatar
the truck has a cold weather idle bump that is vacume acutated.
so truck is cold... puter calls for idle bump = vacume leak till it warms up and closes the vacume switch = normal
Old May 23, 2007 | 10:21 AM
mt_goat's Avatar
Yeah when you say "night" do you mean as in cool or lights on?
Old May 23, 2007 | 10:41 AM
yotasavg's Avatar
i mean as in like the sun has gone down. my lights can be on or off. it just does it at night time. i know that sounds stupid, but theres no other way for me to explain it. temperature at night hasn't been that different from day lately and this only happens like after my trucks been parked and i'm leaving some where to go home and sleep.
Old May 23, 2007 | 10:42 AM
yotasavg's Avatar
ya sure. but it should be able to run on it's own without me having to hit the pedal.....right?
i also feel a lot of slack in the throttle cable. could this be an issue for low idle?
Old May 23, 2007 | 11:01 AM
OSIRIS's Avatar
not if there is a vacuum leak. If there is a vacuum leak, then you don't have a properly pressurized manifold. Run your in the day, then take off the oil filler cap. It will bog down and won't run well, put the oil cap back on and it will purr like a kitten.
Vacuum leak makes sense. Follow his lead.
Old May 23, 2007 | 11:07 AM
mt_goat's Avatar
Is it in a bad area of town? I know I get scared of the dark when I'm in a bad area hehe.
Old May 23, 2007 | 11:09 AM
yotasavg's Avatar
i do hang out in the ghetto...........hahaha
i want a new engine.
Old May 23, 2007 | 11:11 AM
INFINITY's Avatar
all of the drunk drivers need this mod on their vehicles... have no clue good luck
yotasavg's Avatar
wait up, so you're telling me to do what? i'm sorry i didn't follow that.
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
