fricken dome light
Old May 15, 2007 | 05:46 PM
gravy's Avatar
fricken dome light
my 86 runner dome light isnt working. hasnt worked since i had the truck. never really thought twice about it. after a while i forgot i had a dome light. today i started looking at it more, and found the bulb is fine, the wired are fine, fuses....fine. it sucks when i'm lookin for something at night, and cant see squat. any suggestions?
grav
Old May 15, 2007 | 07:10 PM
MMA_Alex's Avatar
flashlight?
if the wires, bulb, and fuse are fine then its the switch. one of those has to be broken or it would light up. got a multimeter? start tracing, and see if all the connections are good. If the bulb is good it should have some resistance, but not too much, a few ohms tops.
Old May 15, 2007 | 10:04 PM
shoes138's Avatar
go to the junk yard, n get another unit cuz mine did that only the ON would work and not the DOOR. so i went to the junk yard bought myself a new one n BAM fixed!
Old May 16, 2007 | 11:05 AM
gravy's Avatar
thanks, i gotta investigate more. i'll check the local yards. thanks again.
grav
Old May 16, 2007 | 12:29 PM
MMA_Alex's Avatar
figure out where the issue is first. get a multi meter and trace things. if theres a break in a wire putting in a new fixture wont work. dont throw parts at your problems, but instead diagnose whats wrong first, then put in the right part
Old May 16, 2007 | 03:34 PM
javadoody's Avatar
i 2nd the continuity test.
if it proves broken, check on ebay, you may find one that you know works.
anyone know if there an aftermarket that actually throws light? you'd think someone would have a fixture that was more directional--like a low profile RV.
Old May 16, 2007 | 03:36 PM
dijlop's Avatar
just had to throw my 2cents in. girl at schools got a switch that says dome on/off. i love turnin it on. gets a reaction everytime. *evil laugh*
Old May 16, 2007 | 03:49 PM
4Crawler's Avatar
Dome should have power all the time, if not check the fuse/wiring. If the ON switch turns it on, then power and light are OK. Door switches ground the light to turn it on. They often have blocking diodes at each switch (if you have courtesty lights in the doors). Wiring runs up the a-pillar, behind the trim.
Old May 16, 2007 | 04:20 PM
gravy's Avatar
thanks guys for your thoughts. i'm gonna hit it with the test light in the morning, if that proves to work, then the yard i hit.
Old May 16, 2007 | 05:19 PM
MMA_Alex's Avatar
theres a thread somewhere on here where someone used ricer colored lights to test how bright they'd be, and found out that the blue ones in the dome make it look real bright compared to stock, and make the light white, as opposed to the incandescent yellow.
Old May 16, 2007 | 05:37 PM
4Crawler's Avatar
Or drop in a 1watt Luxeon LED, very bright and 1/10th the power of the regular bulb:
http://taskled.com/dome.html
theking11863
Mar 19, 2016 09:36 PM
AkitaDog
Sep 1, 2015 08:05 AM
mr_manny
Jul 31, 2015 10:39 AM
TDonkey
Jul 26, 2015 10:14 AM
msane99
Jul 11, 2015 08:08 PM
