rear shocks
Old May 22, 2007 | 11:11 AM
Jay351's Avatar
rear shocks
I bought some pro-comp es3000 shocks (good for 2" lift) and since it was such a nice day I was woundering, can I do my rear shocks without jacking the ass end up? Can I just unbolt the old ones, compress the new ones, bolt them up and be done with it?
Old May 22, 2007 | 11:21 AM
ewong's Avatar
yup
Id get a helper if possible.
The bushings may be stuck on - use a 2' peice of 2x4 and a mallet to knock the shocks off frou outside the truck.
If the new shocks are high pressure (Bilstiens) I hope yer strong.
Toyota thought to make the stock shock mounts welded studs so its pretty easy to slip a new shock on to the existing stud hanger...
Old May 22, 2007 | 11:25 AM
Jay351's Avatar
The shocks are used ( almost new) so I can pretty much compress them if I put my weight on them. I would amagin I only have to compress it maybe halfway. Should I spray some penetrent before I giv'er? Im just hoping they will be better thent he 16 year old ones on the truck now...
Old May 22, 2007 | 11:36 AM
ewong's Avatar
Toyota was smart - the shocks are held on (at least mine are) via an INTERAL threaded hole in the center of the "pin", not an external thread (as if it were a welded bolt)... the actual nut holdind the shock on is quite small as its not really stressed....
Old May 22, 2007 | 12:39 PM
Jay351's Avatar
holy freakin hell, I got the top bolts off both but the bottoms will NOT budge! Jesus! I was usuing my legs and all I was doing is pushing myself along the driveway.
I sprayed the bolts with some Deep-creap and will go back in an hour and check it out, I sprayed on both sides of the bushing. (not in the bushing).
Old May 22, 2007 | 01:36 PM
Jay351's Avatar
Well I tryed again and they will NOT budge a mm. I soaked them again and I will get a cheater bar or try an impact gun next..
Old May 22, 2007 | 02:03 PM
MMA_Alex's Avatar
get out the old propane torch, and be careful not to heat the shock too much. you'd be surprised what a little heat will do
Old May 22, 2007 | 02:08 PM
Jay351's Avatar
I don't have a torch Im pretty much using a VERY baisic hand tool set.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 14, 2015 10:23 AM
akaphilly
Jul 9, 2015 02:34 PM
