- stock fan & electric fan??
- Poly Bushings Without the Sleeves
- Taurus Fan Saga, Pt 3. Trip over
- 93 T100 engine swap options
- stronger brakes with current master cylinder?
- Looking at a Aussie locker few ???
- Diff is toast...need San Diego help
- Adding more lift need some help
- Optima Red-Top Slowly Dying
- 3" Downey Lift w/ 31 BFG AT
- warning about auto to manual hub swap
- Ceramic vs standard clutch
- Truck Height Uneven
- Guess The MPG Gain!
- 90 3.0 idle all over place after batt disconect
- Altenator Issues
- 87 toyota sounds bad I nead a diagnosis
- I think I need my Kindney's Replace, MY GOD MAN
- Another 3VZE rough \ low idle in gear only
- Driveshaft Swap W/3.4 Conv.
- Got the lift on finally *pics*
- Gear swap calculator...
- Beck/Arnley Fuel Filter
- 89 sas truck general advice wanted
- Hella 500's
- parts source
- can a SAS and ARB bumper co-exist
- 95 4Runner Rear Window... help!
- Plentium Air Leak on a 3.0
- 4wd bumper on 2wd truck Q's.
- Inspired to Dive Into 3VZE!
- Need your opinions on towing travel trailer 22re Auto
- no more sagging
- New 22re motor
- Prerunner lightbar/front bumper
- 2nd gen differential question after reading
- 86 4runner allover the road after bumps?
- Wheel Bearing Grease...
- What do you guy's think about this rig?
- New here and I have a question on my timing
- oil sender or gauge bad.1987 4-runner
- Windshield wiper link or Motor?
- Diff breather question
- Manifold to downpipe doughnut P/N and installation notes?
- cleaning wheel bearings
- Dirtbag Exhaust System
- Front brakes,
- New Gears installed!
- Washer Pump Questions
- would taking off the brush gaurd....86 runner 22re
- rear motor mount
- Idle rpm drop / rough starting
- bigger tires thread.
- AC blowing fog?
- What size BL for 3.4L swap?
- 3vze code 31 with intermittent CEL
- Check engine light codes for OBD1
- 3.4 Rebuild
- Need quick distributer install help!
- Catalytic removal
- Solenoid part #'s needed
- Location of air intake temp sensor 1990 3vze??
- Newbie ? for the 22RE.
- Need verification on changing auto trans & Tcase fluid
- Best Shocks w/ Downey HD's?
- Will a Helicoil be a perminent fix on a rocker arm?
- 89 4Runner ECT prob(not shifting into 1st)
- 4.3 V8 Swap
- Replacing an A/C Compressor
- Rough Idle/missing No Code
- New Here.. in progress head gasket help needed
- running boards / mud flap
- 22re Bling
- 3.4L Swap Exhaust Questions
- somebody tried to steal my 2nd gen last night
- Reg Cab Speaker Enclosures
- R&P Pattern
- Copper Coat good for Head Gasket?
- 1993 PU 4x4 3vz cracked #6 plug
- Shock Bolt ?
- Is the 3.0 that bad a engine, need some info
- Need electrical advise
- Got some new meats today!!!!
- A/C Problems still...
- New Engine
- need new springs w/ downey hd?
- 1987 PU Headlight Size?
- "Seem" to have solved pinging problem...
- new guy here.. bad miss when engine get's hot
- 22re issues
- Want a softer ride. Remove Suspension Lift?
- I hear a tapping when I start the 4runner??
- Where to connect that missing tach cable
- I got a FREE 22re, what would u do to it?
- tryign to keep the mud out
- 3.0 engine died
- Ball Joint spacers safe?
- 88 4R, is it worth it?
- Metal Action 2nd gen bored throttle and matched intake
- 92 pickup presto change-o into 4runner ??
- How to find TDC?
- 86 22re A/C Low Pressure Switch?
- CAM Bolts Again !
- Car won't start - 12v from coil?
- Where is my oil going?
- Help! Is my fan dead??
- Taurus Fan Saga Continues
- 2nd gen seafoam success
- 1986 turbo,2.4l automatic with overdrive xtra cab
- New 3VZE Radiator installed
- 3.0 starter going?
- fender flares on a 94
- Gas And Temp Gauges Both Inop!! 89 4 Runner
- neat discovery on engine parts..
- "Spanner" Tool
- 3.0 engine replacement...no start
- Vibration at 1500rpm
- Parking brake warning light
- 3.0 V6 problems
- Averge time it takes to remove 22re out of engine bay?
- Sputtering and Leaving Me Stranded..
- 90 4 runner clutch bracket repair
- How do I adjust/set the inclinometer?
- AC dilemma
- 22RE cylinder compression/ engine removal and swap questions
- Air Pocket in Coolant Lines/Air Valve Adjustment
- '91 tranny in a '95?
- Upgraded radiator?
- Best way to remove old engine gasket material?
- air conditioning problem
- Help removing 2nd gen CV Axles (in the middle, couple ?'s)
- Rebuilt 3.0 source
- 3vze fuel injector r/r
- Timing Tensioner Question
- Should transfer case lever lock in 4L? (934R)
- Clutch adjustment
- Outside temp effects my idle and a/c high idle.
- Can I get new seats from the dealer?
- speedometer 90 4runner
- 1991 4x4 22re 5Spd Info Needed
- ARGH body lift problems!!
- Mass Airflow Sensor
- It is really time to change that timing belt now
- Just got my 1st 4runner!!! i'm stoked but need advice on maintenance
- TruFilters Oil Filter...
- How do you tell if intake gasket isleaking?
- Torqing head bolts - stripped?
- Damn you lug centric rims!!!
- 1990 3.0 Lacks Power
- VAM testing.....How?
- 3.0 rebuild
- 3.0 Timing?
- 94 2wd yota p/u gearing
- 88 3.0 will not start
- Power Window problem (front) 88 4-Runner
- 3.0 power problems solved
- Can the number 3 camshaft bearing cap leak oil?
- Failing TPS symptoms
- What did I screw up? Car won't start....
- Bodylift,gear shift question
- gas pedal free play
- Bigger altenator???
- 88 extended cab read seat question
- white or black herculiner?
- I Need New Replacement Trim Pieces And Center Console
- power windows
- Engine spark, engine die
- newbie..saying hello
- not sure about my 95 4Runner having lift
- Help with 7-pin trailer connector & brake controller
- Can't get Injecter's to fire.
- Anyone have a 1994 4runner FSM?
- holley 2300 500cfm carb on 22r
- Fuel filter replacement tips..for the novice!
- A/C problem
- code reading, injector cleaning, etc questions
- busted nut
- 1993 Pickup: SAS Death Wobble Problems
- '95 4Runner mods I would do again....:
- I want 44s!
- code 2 and 4 or 42?
- Code 51 when doing anything cept idling.
- AC removal? 87 Auto
- Front CV Boot Repair Help
- Project Snowball: Intake tube mod...
- Another Lift Question...
- Good price for machine shop to "do" head?
- Taurus/Sable/Lincoln Fan Update
- Shifting Problems - Replace Bushing?
- Where does this hose go?
- 87 Runner: front locking hubs, manual or automatic?
- Overheating driving me crazy
- Loud iregular tapping
- 94 22re Brake Light & Batt Light + Overheating
- 4crawler BL
- 89' Pickup paint fading
- truck just wont start
- OME vs Downey vs Alcan rear leaf springs
- Expencive few weeks for me but the runner loves it
- off-road light options....
- Help Starter problems
- Missing #3
- starting issues 89 3.0
- whistling
- Check this 88parts truck out on theBay *cheap*
- rear suspension sag
- Lift Order List
- 4cyl engine for a 1990 4x4 truck needed!
- Door Hinges?
- oil pressure
- Can I turn a 22r into a 22re?
- Header response
- 2nd gen rear bumper ideas
- Bleeding gear box
- Can someone ID this trans for me please *pic*
- Jacked my tailgate, know of good dent pullers?
- Leaking Coolant
- approx engine idle speed during warmup when outside temp is 90+
- overdrive
- 3vze noise, not a lot to go on...
- I need help fast on broken stud!!!
- Its official, my truck does not like me.
- Cam Plug oil leaks!
- 86 PU CLUTCH..need some advise
- 4wd light stays on... help?
- 92 4runner 3vze engine trouble
- 4runner 86 Bed modifications
- What Bug Deflector to Buy?
- Source for intake screw
- Sputtering 3.0?
- 93 runner dashboard removal help
- EGR Valve Temperature Sender
- 3vze + auto tran install help
- fan cluch bad or what
- 2nd gen magnaflow/glasspack question
- Labeled a "Gross Polluter" today at the smog test!
- Help with in-process 3vze vlv cover gasket job
- very bad gas mileage
- Paint code
- BORLA CATBACK ROTTED OUT!! and I think they sent me the wrong repacement part!
- how to remove pulleys?!
- Is your automatic as sluggish as mine?
- fault temp sensor, correct gauge?
- Cam position installation question
- Which one-uh these is the temp sender? *pic*
- Rotating crank and cleaning pistons
- thorley header question
- westin safari bars
- Bad Injector?
