92 4runner 3vze engine trouble
Old Jul 15, 2006 | 05:58 PM
brian3nj's Avatar
I have a 1992 4runner 4wd 3vze automatic. When started cold it runs ok for about 3 minutes. Then it will only idle or run at full throttle, anything in between and it will sputter and stall. I changed the TPS, removed the injecters, checked and cleaned them. Egr valve was removed and checked. There is no check engine light.
Old Jul 16, 2006 | 09:58 AM
brian3nj's Avatar
I found an old thread that suggested disconnecting the TPS. When I did this the engine seems to run ok but with less power.
https://www.yotatech.com/forums/show...ight=ignighter
Old Jul 17, 2006 | 10:40 AM
brian3nj's Avatar
Could this be a bad engine control module?
Old Jul 17, 2006 | 10:44 AM
TNRabbit's Avatar
Possible, but not likely unless you've sunk it in water.
Old Jul 17, 2006 | 12:10 PM
brian3nj's Avatar
never sunk in water!
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
JF9243176
Jun 24, 2015 04:53 AM
ra72
Jun 16, 2015 11:10 AM
