4crawler BL
Old Jul 17, 2006 | 08:40 PM
95RunnerSR5's Avatar
4crawler BL
in the typical 3" kit does the $156 cover the lift blocks too?
Old Jul 18, 2006 | 03:32 AM
RustBucket's Avatar
Dispensive with the frivolities and just email RB.
Old Jul 18, 2006 | 03:47 AM
seaflea's Avatar
I would think so.
From his web page;
Introduction:
The body lift kits consist of the following items:
Body lift blocks:
Ultimate blocks in UHMW polyethylene:
2 - 2" OD and 4 - 2.5" OD blocks for the cab
8 - 2" OD blocks for the bed
Natural color is white, may be custom colored in black with the CLR option
Also available in cab-only and standard size (all 2" OD) blocks.
For lifts between the heights listed below, use the next higher kit price, e.g. for a 1.5" lift, use the 2" pricing
Hardware is available in several options.
Standard grade (Grade 5) hardware is included in kits D, includes longer bolts for each body mount location
Hardware may be upgraded to Heavy Duty (Grade 8) by ordering the HD option
Front Bumper brackets to raise the stock front bumper to match the lift
On '83 and earlier 4WD and '88 and earlier 2WD pickups, inquire about front bumper brackets
Radiator drop brackets to lower the radiator to align with the stock radiator fan
Bed Spacers can be used to support the center of the cargo bed over the rear wheels, if needed
Shift lever extensions that screw onto the shift lever to extend it 2" or 3" to match the lift
Automatic transmission/transfer case bracket extensions for externally shifted transfer cases
Polyurethane body mount bushings replace the stock rubber bushings, if needed.
Lift heights up to:
3" on 1979 - 1995 4WD, manual and automatic transmissions included
2" on 2WD with manual transmission
Up to 1" on 2WD with automatic transmission
Including bumper brackets for the 2WD pickups
Kit 1" 2" 3" Description
B $ 60.00 $ 76.00 $ 92.00 Ultimate Lift Blocks
D $ 85.00 $101.00 $117.00 B + Standard grade hardware
HD $ 15.00 $ 15.00 $ 15.00 Upgrade Kit D to Heavy Duty hardware
CLR $ 14.00 $ 14.00 $ 14.00 Custom color
FB $ 10.00 $ 10.00 $ 10.00 Front bumper brackets
RAD $ 15.00 $ 15.00 $ 15.00 Radiator drop brackets
SL n/a $ 15.00 $ 20.00 Shift Lever Extension (per lever)
AT n/a $ 40.00 $ 50.00 A/T linkage brackets
SE n/a $ 30.00 $ 30.00 1" Steering Shaft Extension (if needed)
BS $ 8.00 $ 10.00 $ 12.00 Bed Spacers, per pair
P $ 85.00 $ 85.00 $ 85.00 Polyurethane Cab Mount Bushings
DOC $ 2.00 $ 2.00 $ 2.00 Printed installation notes
Typical D+FB D+FB+RAD D+FB+RAD+SE Typical Kit Combination
Cost $ 95.00 $126.00 $172.00 + applicable sales tax and shipping
nvwiggins
13
Jun 16, 2016 03:05 PM
JUICE222
Oct 13, 2015 08:50 AM
crash813
Sep 27, 2015 07:15 AM
AkitaDog
Sep 3, 2015 09:01 PM
sphealy
Sep 3, 2015 07:55 PM
