How to find TDC?
Old Jul 24, 2006 | 06:46 PM
rcm3's Avatar
How to find TDC?
What's the easiest way to find top-dead-center? Is there markings on the crank or do I have to put a coat hanger in the #1 plug hole?
Old Jul 24, 2006 | 06:59 PM
LS1Steve's Avatar
there is a mark on the crank. put a wrench on & turn till it lines up with the mark
Old Jul 24, 2006 | 07:00 PM
trx125's Avatar
pull dist cap off, turn the crank and align the crank mark with the 0 mark on the timing cover, the rotor should point @ #1 plug tower of the dist cap, if not rotate the crank one full revolution and realign mark. you should now be @ TDC, unless the motor has jumped time! You are looking for TDC of compression stroke, not just TDC!
Old Jul 25, 2006 | 05:25 AM
rcm3's Avatar
That was the answer I was looking for. I knew there had to be an easier answer to finding tdc, and the distibutor completely slipped my mind. Im used to working on newer cars without them.
polo451
13
Nov 20, 2016 07:49 PM
thefishguy77
Jul 30, 2015 10:59 AM
HookahRoo
Jul 20, 2015 07:06 PM
scottyg486
Jul 19, 2015 05:34 PM
sojourner567
Jul 16, 2015 08:52 PM
