overdrive
Old Jul 16, 2006 | 01:57 PM
95RunnerSR5's Avatar
overdrive
Well i left my truck sitting at a parking lot in the university parking lot while i was at camp for three days...i didnt drive it in those three days and for some reason my overdrive only kicks on halfwayish...normally when its on i run 2500rpm's at 60mph but now i'm running at 3000 at 60..its a pain because when i run on the highway at 80 i'm doing damn near close to 4000 rpms and my a/t oil light comes on until i slow it down for a while. it hasn't done this before and it is fine on trany fluid and i replaced the filter and fluid less than 1000 miles ago. please help anyone... its a 1995 4runner auto tranny 3vze
Old Jul 16, 2006 | 04:30 PM
Marc's Avatar
It might not be your overdrive but the torque converter might not be locking up.
That would cause your tramsission to get hot.
To check it, push in the O/D switch and see if your revs go up. If they do, then it's definitely a problem with the lock up.
Old Jul 16, 2006 | 05:16 PM
i when the O/D button is in the off position and the dash light is on the revs go up like they're supposed to but when i press it back to the on position they go down but not as much as before. how could sitting for three days cause this?
Old Jul 16, 2006 | 05:21 PM
Elton's Avatar
im guessing your truck didint like you leaving her for 3days
Old Jul 16, 2006 | 05:30 PM
that or the fact that i havent been wheelin in a while is gettin to her..hopefully it will work tomorrow...
Old Jul 16, 2006 | 05:56 PM
mt_goat's Avatar
The only way I can think of is an ATF leak, have you checked your ATF level?
Old Jul 16, 2006 | 05:59 PM
yeah man it hasn't leaked a drop. the level looks the same on the stick and underneath is dry as a bone. maybe too much fluid?
Old Jul 16, 2006 | 06:03 PM
mt_goat's Avatar
If the ATF level is ok, then check the solenoid that locks up the torque converter.
Old Jul 16, 2006 | 06:09 PM
mt_goat's Avatar
Here is the transmission part of the 93 FSM, my guess is you have the A340H tranny (if 4WD). http://personal.utulsa.edu/~nathan-b...autotrans.html
Old Jul 16, 2006 | 06:38 PM
i'm really lost about what could be causing this problem...because the torque converter does lock most of the way, just not as much as it did before
Old Jul 16, 2006 | 07:01 PM
mt_goat's Avatar
How do you know? My thinking (I could be wrong) is that when the TC is unlocked there is only a slight slipping at higher RPMs.
Old Jul 17, 2006 | 07:30 AM
Marc's Avatar
When the tc locks up it only drops about 500 rpm.
Old Jul 17, 2006 | 08:33 AM
i know it locks up because when driving with it off i can turn it on with the button and watch the rpm's fall....
Old Jul 17, 2006 | 09:04 AM
mt_goat's Avatar
What button? There is no button that I know of (stock anyway) that controls the TC lock-up. You must be confusing the OD on-off button for a TC lock-up maybe?
Old Jul 17, 2006 | 09:28 AM
Marc's Avatar
Overdrive is fourth gear. The TC drives the transmision.
Old Jul 17, 2006 | 09:36 AM
oh my mistake...my torque converter isn't locking up then for some reason. i had the o/d button confused.
Old Jul 17, 2006 | 10:10 AM
mt_goat's Avatar
When you get it fixed be sure to do a transmission flush because those ATF overheat idiot lights don't come on until the ATF is really hot and cooked. When the TC is unlocked the slippage generates a lot of heat. I wouldn't drive it myself until it's fixed for fear of transmission failure due to overheating. Here is some good info on tranny flushing: http://www.gadgetonline.com/TransFlush.htm
Old Jul 17, 2006 | 06:48 PM
how do i check my lock-up selenoid so see if it is working or not?
Old Jul 17, 2006 | 06:57 PM
mt_goat's Avatar
See the link in post #9, Go to A340H, electronic control system, AT-130 on page 11 of 13
Old Jul 17, 2006 | 07:21 PM
alright thanks for everything.. i'll begin checking different things tomorrow
Liadrin
Apr 25, 2022 02:54 PM
chuckross1957
Jun 28, 2019 10:19 PM
crammit442
7
Nov 29, 2017 12:30 PM
rmill05
Sep 27, 2015 01:43 PM
keithporter83
Jul 24, 2015 07:37 AM
