I got a FREE 22re, what would u do to it?
Old Jul 25, 2006 | 03:56 PM
Adams90Toyota's Avatar
I have a 90 pickup that I am still trying to get to run but that another thread..lol..Any way I just got a stock 22re gave to me by one of my dads friends. What are some low cost motor upgrades to do? Nothing like turbo just simple stuff.
Old Jul 25, 2006 | 03:59 PM
sdstud212001's Avatar
bridge them together and have a straight 8
Old Jul 25, 2006 | 04:05 PM
4Hummer's Avatar
Rebuild the motor, Larger pistions and rings, Master gasket set, new timming chain, oil pump, water pump,
Dont forget the Head, Cam and valves will yield you good results.
all from ted at engine builder
Old Jul 25, 2006 | 04:06 PM
Elton's Avatar
my old 22re with 167k on the motor i added a lce header custom intake and 2-1/4'' exhaust all the way back it made good power for a 4cly
Old Jul 25, 2006 | 04:40 PM
4Hummer about how much will that cost?
Old Jul 25, 2006 | 04:41 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
bore and stroke upgrade! haha thatll be a decent amount of money.
Old Jul 25, 2006 | 04:51 PM
Elton's Avatar
ya its not going to be cheap a full rebuild like the will set you back atleast $2500 bucks
Old Jul 25, 2006 | 05:36 PM
Could u make a 22re, carb, and not all that wiring and b/s? and what is better progormence wise 22re, 22r?
Old Jul 25, 2006 | 05:41 PM
Elton's Avatar
why efi is better than a carb
Old Jul 25, 2006 | 05:57 PM
Well efi r alot of wires and stuff to get in the way like my truck now something in the wiring went wroung truck well not run but to tell the truth im thinking of a 87corolla i want to get into drifting alot of my freinds started (www.driftwilkes.com) i know this is a fourwheel web site but i need chep power.
Old Jul 25, 2006 | 06:01 PM
jwbehm's Avatar
Just got back from Fast and Furious? Haha just messing with ya
Good luck with it
Old Jul 25, 2006 | 06:03 PM
now dont get it wroung i go 4-wheelin alot thats why the truck is in the shop...lol...but got to love the yotas...
Old Jul 25, 2006 | 06:41 PM
Sonofmayhem's Avatar
i would rebuild it with the eng builder kit off of ebay for 350, and then do it slowly, thats what i plan to do. you can have someone do a rebuild for you for 2500 here, w/ towing and labor.
Old Jul 25, 2006 | 07:03 PM
I dont just want to rebuild it i want to make it a fast high RPM motor.
Old Jul 25, 2006 | 07:04 PM
Elton's Avatar
buy a turbo or a superchager well if fast is what you want try a 5mge or 7mge swap
Old Jul 25, 2006 | 08:41 PM
to much $$$$$$
Old Jul 25, 2006 | 08:54 PM
1985 4Runner's Avatar
Give it to me, I'll put it in here:
Rebuild it yourself if you know how, if not you will have to spend some cash.
Old Jul 25, 2006 | 09:22 PM
95RunnerSR5's Avatar
you should find a LC engineering style preformance kit and then add a turbo or supercharger to it!
Old Jul 26, 2006 | 05:26 AM
4Hummer's Avatar
Under $600.00 Canadian for my rebuild, and that includes paint, new plugs wires, cap/rotor. vacuum lines,
Pistions, Rings, bearings, Bore the block, master gasket kit, Timming chain, oil pump and water pump. timing chain cover.
$2500 (Are you smoking crack?) some people sure like to throw out usless infomation without having any real knowledge or facts about it
From Teds Site
http://www.engnbldr.com/ToyotaHotLicks.htm
P900 Piston Set (std, .020, .030, .040 available) $60.00
EPNR900 Ring Set (std, .020, .030, .040 available) $31.00
FGS9000 Full Gasket Set ` $60.00
OP900 Oil Pump $53.00
TKS900SR Timing Chain set / Driver side steel rail $64.00
Full Bearing Kit Rods, Mains, TW $60.00
COV900 Timing cover $54.00
Total: $382.00
machine shop changed $25 per pistion to bore.
Talk to Ted and he can throw together an Ala Carte Specail
Or
MASTER ENGINE KIT SPECIAL!
$219.00
(less cam / cover)
Master engine kit includes: Pistons, rings, full bearing set (rod bearings, main bearings, and thrust washer set), timing chain set ( OUR engnbldr steel rail kit), oil pump, full gasket set (complete with front and rear seal and OEM style steel clad viton valve stem seals), and brass freeze plugs.
Old Jul 26, 2006 | 05:41 AM
RustBucket's Avatar
Just buy the Corolla and sell the 22 to someone on the board here...
