Bigger altenator???
Old Jul 20, 2006 | 11:38 AM
bigpest88's Avatar
Bigger altenator???
Ive been wanting to put some lights on my roof rack, but I was wonedering if the stock altenator can hold up? If not, what would I need to do? Bigger altenator maybe?
Old Jul 20, 2006 | 12:06 PM
mastacox's Avatar
The stock alternator is only 60 amps... The ignition takes something like 20 amps, odds and ends might take another 10 unless you're using the rear window defroster or some high current extra. SO theoretically you'll only have max 30 amps to spare... You can search for "alternator" and will find many wonderful threads full of info for upgrading.
Old Jul 20, 2006 | 12:42 PM
the_supernerd's Avatar
To figure out how many amps the lights require, use the equation amps X volts = watts. Two 60 watt lights will use 10 amps. I have had up to 3 sets of 55 watt lights on my truck and it was fine.
Old Jul 20, 2006 | 02:44 PM
mastacox's Avatar
I have a pair of 130W Hella 500's, they are awesome and super daylight bright, but they suck down about 11 Amps each, 22amps total. I upgraded to the 100 amp MR2 alternator a while back though to keep up with my electric fan.
Old Jul 20, 2006 | 04:41 PM
midiwall's Avatar
Originally Posted by mastacox
I upgraded to the 100 amp MR2 alternator...
And, how was that to do? Is it a drop or is there a bracket fab?
My Mr. Alternator is junk and it's time to go.
Old Jul 20, 2006 | 05:27 PM
ovrrdrive's Avatar
GM alternator swap for the win...
I have this on my list even if I don't do the SBC swap next year. This link gives the part number of a GM 105 amp alt:
http://www.toyotaoffroad.com/Article.../Chevy_Alt.htm
I saw a better writeup of this job, but I can't remember which forum it was on and I can't find it... I'll keep looking.
Old Jul 20, 2006 | 05:59 PM
mastacox's Avatar
It was really easy! You do have to modify the bracket (extend it to be exact), so you can either weld on an extra piece of metal, or if you don't weld you can just make the extension and then drill two holes through the arm and extension to put two bolts in. You also will have to get a longer belt, and drill the connector that bolts on to the alternator a little bigger. I talked about a write up a while back:
Offroad.com Write Up
The alternator isn't super cheap new, around $170, but you could theoretically search some junkyards if you felt up to it.
Old Jul 20, 2006 | 06:04 PM
LOCKnGO's Avatar
This is the one I hope Santa brings for christmas! MWAaHAHAHA POWER!
Old Jul 20, 2006 | 06:10 PM
mastacox's Avatar
Yeeeesssss, excellent...
A GM 200 amper is what I'll aim for!
Overkill? No such thing
Old Jul 20, 2006 | 06:40 PM
LOCKnGO's Avatar
Overkill? My plans are to get a 2000 watt inverter, duel optimas and enough lights to turn street lights off at light. *EVIL LAUGH* ...oh yeah then someday a winch and.......
Old Jul 20, 2006 | 07:00 PM
mastacox's Avatar
LOL you might as well go for one of the on-board welding systems, they come with something like 500 amp ones I think... You can be a driving 150hp 6 Kilowatt generator !
Old Jul 20, 2006 | 07:14 PM
LOCKnGO's Avatar
YESSS!
Would that be overkill?
Old Jul 21, 2006 | 11:59 AM
da_bigg_wigg's Avatar
No Such Thing As Overkill
Old Jul 21, 2006 | 12:03 PM
gregbreakseverything's Avatar
I charged 2 batteries running 3 KC daylighters, and a 1100Wp-p stereo no problem on my stock 22r altinator. I had to replace the brushes once though.
Old Jul 21, 2006 | 01:28 PM
midiwall's Avatar
Excellent! That's what I was hoping for!
That's cheaper than my Mr. Alt. was ($235, 3 years ago).
Old Jul 21, 2006 | 01:31 PM
gonzo's Avatar
I have 4 front AND 4 rear 100w aircraft lights, 2 - 450w amps for the stereo with 1 stock battery. The stock alt. will keep up with 4 lights on at once for about 20 min. then I start seeing a drop in the volt meter. Thats with the truck just idling and the a/c on. I am putting a hand throttle on this weekend so I can bring it up off idle if I need to.
Just my 2c
Old Jul 22, 2006 | 05:40 PM
94-RUNNER's Avatar
You might want to give this a try if you really want a good alternator. Not the cheapest out there but you get what you pay for. Mine was a direct fit, no mods at all. I run a winch, lights, 1000 watt inverter, Engel 45 cooler and lots of other junk and have never had a problem.
Just my views on what I've done.
http://www.excessiveamperage.com/
foampile
Dec 18, 2022 01:29 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
Steven.m.paulk
Aug 16, 2015 04:52 AM
Dakotaneu
Aug 15, 2015 07:24 AM
matrad
Aug 8, 2015 03:00 PM
